YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Tires & Wheels
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-28-2008, 04:46 AM   #26 (permalink)
xcmountain80's Avatar
No a 285 Interco SSR is more like 34" tall at 33.9" where as a Maxxix bighorn is a mere 33.3" in the 255. While I realize most other 285's are far smaller than the interco it is the outlier. Though at the same time wer were talking about the difference btwn a 35 and a 31 not skinny vs wide. And while ExpWest has a valid argument and well written article cornering an on ramp at 60 with 255's isn't going to give you the same results as with say my 295's. I realize lateral force is at play here and I don't believe that was covered in the ExpoWest article.
Aaron
__________________
02 4Runner, BudBuilt Skids, Custom Sliders, 1"+/- wheel spacers, Nitto 295's, Painted Limited Wheels, TJM-17, ARB-Taco BullBar, LightForce 240's, 1st Gen rollbar, Engel 45 with custom slide, SS 3" Lift, WabFab 1" BL, SS limit Straps, Viair 450C, Aussie Locker Manual hubs and Tru trac with 4.56, Garmin 276c, Icom V8000, Cobra 75, Hannibal RTT, Shady Boy Awning, Tru Speed calibrator, T-Max 9k, 100' MP syn line. Nitto 295's
xcmountain80 is offline
Sponsored Links
To remove this ad, register today!
Old 08-28-2008, 05:32 AM   #27 (permalink)
toyota-erik's Avatar
Quote:
Originally Posted by JasonWin View Post
That's a sig worthy quote if I ever saw one!
damn it! I should have known that would be used against me. Oh well, glad I could help
__________________
81 Toyota P/U, 22R with GotPropane kit, wheelbase stretched 5", bobbed box, narrowed tube frame from cab back, full exo, tube doors, Warn 9000i, 36" IROKs,TR bead locks, 4 link front, 3 link rear, Fox 2.0 16" all around. Rear axle is shaved, trussed, V6 3rd, CroMo axles, 4.88, full spool, and disc brakes. Front axle is trussed, HP 3rd, 4.88, 30spline Longfields, and a lunchbox locker. Full hydro Howe desert series race pump(reworked by PSC), CroMo steering arms, 4.7:1 t-case
toyota-erik is offline
Old 08-28-2008, 05:41 AM   #28 (permalink)
dirtoyboy's Avatar
Quote:
Originally Posted by berzerkrobot View Post
TC, that statement definitely perplexes me..... I instantly think of how wide racing tires are, esp on f1, indaycar, nascar. Theres no way a tire 1/3 the width of those tires would provide the same grip/traction, or am I missunderstanding something?
Seems to me that the amount of traction would depend on the conditions...
here is an interesting article for your reading pleasure
http://www.expeditionswest.com/resea...tion_rev1.html
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 08-28-2008, 05:45 AM   #29 (permalink)
saitotiktmdog's Avatar
Has to be the dumbest question I hav ever heard in an offrad forum. Should go int he dumbest things you have ever heard about cars thread.
__________________
1994 toyota 4x4. 22re turbo (sds em4, intercooler, steedspeed manifold, garrett t3) 4 inch procomp stage two lift. ARB bull bar and warn winch, Quick lock rear, tru trac front 31x10.50 firestone destination MT, 5.29 gears
Planned mods. , T-case gears, ditch ifs
Beware the groove
saitotiktmdog is offline
Old 08-28-2008, 06:27 AM   #30 (permalink)
littledipper's Avatar
superswamper has some 32 10.50 some of the toyotas you have to lift for bigger tires
__________________
2000 toyota tacoma
bone stock
littledipper is offline
Old 08-28-2008, 06:39 AM   #31 (permalink)
dirtoyboy's Avatar
Quote:
huh
This is not a dumb question, either saito...its been a hot topic among wheelers for years
Maybe you have the correct answer?
__________________
Old 08-28-2008, 07:53 AM   #32 (permalink)
ocdropzone's Avatar
__________________
~Robb
'81 Trekker SR5 B4Runner Build
'89 Tercel Project POS Gas Saver
TREKKER Forum
LINK TO ONLINE FACTORY SERVICE MANUALS
All Toyota Website Search Engine
Wheel Responsibly, Don't screw it up for others...
Last edited by ocdropzone : 08-28-2008 at 07:54 AM. Reason: nevermind, wrong thread, wrong thought
ocdropzone is offline
Old 08-28-2008, 08:58 AM   #33 (permalink)
tc
tc's Avatar
See the formula - there is no factor for area - just coefficient of friction and force. The coefficient of friction for rubber on asphalt or concrete is about 0.8.
The reason they have wide tires is often more for stability and heat dissipation, not traction. Look at how F1 tires have the big grooves - the tires may be wide, but there's not that much rubber actually in contact with the ground!
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 08-28-2008, 09:45 AM   #34 (permalink)
Quote:
Originally Posted by dirtoyboy View Post
huh
The point of big tires seems pretty obvouse to me. Exactly how big to go is different. I guess i just find it obvious that larger tires are put on the increase the ground clearance between the axle, springs, a arms etc in order to better negotiate obstacles of larger size. And yes in a lot of cases a lift is necessary to clear the tires.
__________________
Beware the groove
Old 08-28-2008, 10:11 AM   #35 (permalink)
From what I've heard and read, wider tires are good for "floating" over terrain, whereas skinnier tires "Cut" into the terrain. Skinnier is better on ice and snow (how deep depends on how much clearance you have) cause the pressure per square inch is higher giving better traction. The skinnies cut through the snow to what is hopefully solid ground.
Go here to see what i mean by floating over the terrain. Particularly the second video and the snow scene in the first video. Wider tires spread the down force over a larger area, which reduces the pressure per square inch.
Taller allows you to go over larger objects or through deeper water, snow, mud, etc without bottoming out.
__________________
92 4Runner 5 spd V6 31X10.5X15LT
nv4runner is offline
Old 08-28-2008, 10:16 AM   #36 (permalink)
algranger's Avatar
Quote:
yeah thats definitely goin in my sig now everone will know about your penis hehehe..
as for the tires mainly you will have a much easier time climbing over obsticles, going through ruts or anything you will have more clearance for your diffs and they grip better basically it depends on what kind and how much wheelin youll be doin id say a rear locker sounds like it may be what you want before larger tires
__________________
Hi-Tech Redneck
algranger is offline
Old 08-28-2008, 10:27 AM   #37 (permalink)
Quote:
Sorry people, Im going to have to agree here. It would be like going to a drag racing forum and asking "whats the point of having a lot of horsepower?" If your not going to wheel it then there IS no point in having large tires unless you're just a poser.
Quote:
Depends on what type of snow and how deep it is. A skinny tire wont help you in 5' of snow
__________________
Old 08-28-2008, 10:43 AM   #38 (permalink)
A skinny tire might not even help in 4' of snow, but just about anything below the body of your truck they should be able to handle, which is why i added the part about depending on your clearance. The only times I've been stuck is in snow up to my bumper with the 31's without chains.
__________________
Old 08-28-2008, 11:17 AM   #39 (permalink)
berzerkrobot's Avatar
Tc - the actual reason they started putting the groves on f1 tires was to reduce the amount of traction because f1 cars were corning so fast that is was becoming a safety issue. seems ironic.. but thats how the f1 sanctioning body works. Im fairly certain the did the same thing by making the brakes smaller. and then finally cutting the engine size from v10's to v8's. Your'e right about the heat dissipation though.
Another example: Drag cars.
__________________
'97 T4R SR5 4x4 | Detroit Lock'd Rear Diff | Toytec lift w/OME shocks | Diff Drop | 33" Cooper STTs on 15x8s | Glasswerks Unlimited 4.5" prerunner flares | Rear control arm skids | 10lb co2 onboard air tank w/regulator | Hella FF1000s | Custom steel front and rear bumpers, Line-X'd | Air Intake Mod
berzerkrobot is offline
Old 08-28-2008, 11:24 AM   #40 (permalink)
TC4RNR's Avatar
next question, please....
credit to 01rnrgirl, see trail report section.
__________________
http://i172.photobucket.com/albums/w...gca/agreed.jpg
94 4Runner, SR5 3.0V6, 4WD, 5spd: SOLD
99 4Runner, SR5, 3.4L 4WD, 5spd. 265/75/16 BFG A/T. full SS 1.2 lift, RedLine Fluids, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, roof busket, hitch mount tire carrier, Tundra Brakes, Brembo rotors, BudBuilt skid/belly, Lightforce 240 Blitz, PiAA HID, Stubb's HD-SKO sliders.
TC4RNR is offline
Old 08-28-2008, 11:53 AM   #41 (permalink)
4Crawler's Avatar
I've had 33x10.50 tires in 4'-5' deep snow (aired down to about 6-7 psi) and just before I stopped to take the picture below was pushing through snow over the hood:
Finally did get stuck rounding a steeply banked corner, had snow to the top of the door on the driver's side:
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-28-2008, 11:56 AM   #42 (permalink)
Ferrari, Labrogini etc still have v12 engines. I don't think its a cylinder number as much as a horsepower cap. Ferarri engines are v12 because thats what they use in there cars
__________________
Beware the groove
Old 08-28-2008, 01:15 PM   #43 (permalink)
tc
tc's Avatar
Funny car/top fuel car tires aren't really that wide once they get spinning ...
__________________
tc is offline
