| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
What other maintenance should I do?
__________________
"Talk does not cook rice" -Old Chinese Proverb |
#2 (permalink) |
Not much left, let's see. The rubber bushings all around; suspension, shocks, control arms. The steering components need checked, aside from the pump. Fuel filter.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 04-10-2007 at 11:34 AM. |
#3 (permalink) |
Thanks Mudhippy.
Anyone else with suggestions or comments.
__________________
#4 (permalink) |
Before taking it in for a timing belt run some coolant cleaner through your coolant system. I used coolant flush by Prestone. Basically you add it to the radiator and drive around for a few days then flush it out. That way after the timing belt (and new water pump) you'll have an excellent cooling system for your motor.
Also, prior to changing out spark plugs research into running some seafoam through your intake. I think the usual point is a vacuum hose. Do a search here for seafoam. I say before changing your spark plugs because some have said they think it causes fouling of your plugs. This is my plan for my 4runner before I change plugs next. Prior to changing out oil pan gasket think of running Auto-Rx through your motor. I used that on the 4runner and I think it did a great job of cleaning up some of my seals. It stopped the rear main oil leak. Search here for auto-rx to decide if that's for you or not. I may even have a few extra bottles in my garage I'll sell to you at the group discount price as I ordered $100 last time to get all the discounts. Doing it before the pan vice after is probably a mute point but it would be nice to see how clean your pan is after running it through. You may not need auto-rx since you said you have new bearings. I would base it on how your rockers and valves look under your valve cover. If you see a lot of dark, burnt on oil, then maybe think of doing it. What kind of shape are your radiator hoses in? What about air filter, pcv valve? Also, make sure they replace the front camshaft seals when replacing your timing belt. If valve cover coming off to adust the valves, then ask him to replace your rear camshaft seals as well. Cheap parts but they like to leak in high mileage engines.
__________________
1985 pickup std cab 4wd rebuilt 2.4L 22r by Oregon Engine Rebuilders, RV cam, oversize valves, Weber 34 DGEC, 8k on engine,5 speed, OME shocks N93/N85 front/rear, rear diff breather, Durabak interior, Summit proportioning valve, SR5 cluster mod, 3" RB body lift, warn winch brushguard with harbor freight winch, custom rear bumper, FROR floating rear axle with pickup disc brakes all around |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Why I do my own maintenance! | ugadawg95 | Off Topic Talk | 22 | 08-24-2006 10:45 AM |
| What maintenance needs to be done? | Haniblectre | Maintenance & Repair Archives | 4 | 10-17-2005 06:14 AM |
| Some ?'s about maintenance. | READYFORTHEGRIDLOCK | Maintenance & Repair Archives | 7 | 08-26-2005 07:09 PM |
