What is broken on YOUR Toyota - Page 4 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-21-2004, 10:48 AM   #76 (permalink)
Keggo's Avatar
Right... I forgot about the power antenna being broken... any advice on what kind I should replace it with? I was looking at the shorter rubber coated ones... but, then again... how is the reception on those???
__________________
- Kevin E. G.
SOLD!!!
'91 4Runner SR5 V6 5spd: CLICK!! FOR SALE NOW!
Proud dad of Kai E. G.!
Keggo is offline
Old 11-21-2004, 12:38 PM   #77 (permalink)
kyle_22r's Avatar
*takes a deep breath*
clutch master leaks on the floor
clutch slave is out of adjustment
transmission synchros are going out
shifter needs new side linkage bushings
engine front main seal is gone, low compression, going through a quart of oil every 500 miles
carburetor gasket toasted
front axle seals and knuckle seals are gone
rear axle pinion seal leaks
it'll all be fixed very soon, i get my 22R block back from the shop tomorrow and i'll be buying an L52HD tranny from marlin
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 11-22-2004, 08:54 AM   #78 (permalink)
X-AWDriver's Avatar
I can honestly say "nothing" on my '99.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is offline
Old 11-22-2004, 08:58 AM   #79 (permalink)
4RunnerFever's Avatar
Send a message via AIM to 4RunnerFever Send a message via Yahoo to 4RunnerFever
Driver's side cv boot. Just replace the passenger side two weeks ago. grrrr
__________________
2004 Tacoma Double Cab, TRD Off-Road, PIAA fogs, ARE Shell, Yakima, etc. 4RunnerFever
_______
GBNF: 1998-3rd Gen-4Runner, SR5, 4WD, TRD Supercharger, TRD Cat-Back, 3-inch Revtek Suspension Lift, 285/75-16 Revos, 4Crawler Offroad 1" body lift, Sonoran Trac Bar, Hayden Cooler, Hood Scoop, 'Outback' Mod, Optima 34R, Amsoil, Yakima, PIAA, etc. Sold to Mastacox.
4RunnerFever is offline
Old 11-22-2004, 08:59 AM   #80 (permalink)
rimpainter.com's Avatar
Quote:
Do the Taco antenna mod. I just did it and it works great.
The short rubber antennas have horrible reception.
(Not sure if you can do this on a 91 or not...)
rimpainter.com is offline
Old 11-22-2004, 09:25 AM   #81 (permalink)
4Hummer's Avatar
hymmm
Front Drivers CV Shaft >>> Broken and removed.
Exhaust manifold leak. <<< Bolts are stripped need to helicoil them
Rust on both rear fenders
Rust on both rear doors by window.
No Bumpstops
No Speedometer (sp?)
Drivers side door carnage << Doesn't close properly now and dented.
Bad front alignment << Cooked both front tires. I have new Outter Tie Rods and lower ball joint that I need to install than do and alignment.
Thats it
__________________
Michael
1991 4Runner 22RE.
CHOP
www.obsessiveoffroadclub.com
4Hummer is offline
Old 11-22-2004, 10:40 AM   #82 (permalink)
ugadawg95's Avatar
Send a message via MSN to ugadawg95 Send a message via Yahoo to ugadawg95
I need new sill plate covers in oak, i popped the tabs off taking them off and putting them on about a hundred times So if anyone knows where I can get a used set let me know...
__________________
Stephen
SOLD! 99 4Runner Limited, Jade Mica.
08 4Runner Urban Runner Edition 4wd. Blizzard Pearl White...Let the mods begin!
ugadawg95 is offline
Old 11-22-2004, 11:20 AM   #83 (permalink)
lee
lee's Avatar
Send a message via AIM to lee
Quote:
Originally Posted by lee
- one of my rear seats will not fold down
- factory head unit barely works (new alpine goes in on monday!!)
thats .. it =D
i just want to point out that both of these are fixed
lee is offline
Old 11-22-2004, 11:24 AM   #84 (permalink)
Gangus2006's Avatar
Send a message via AIM to Gangus2006
Umm...the cover for one of the rear seat hinge is broken off...One of the Center-Push clips to the dash is broken and superglued in place...One of the friction clips holding in the center stack trim is gone....MY DAMN ALARM DOSENT WORK...I think thats it...
Oh yea, SOMEONE STOLE THE FOG LIGHT PLUGS IN MY BUMPER!
Gangus2006 is offline
Old 11-22-2004, 11:27 AM   #85 (permalink)
lee
lee's Avatar
people will steal anything nowadays.
lee is offline
Old 11-22-2004, 01:45 PM   #86 (permalink)
leiniesred's Avatar
power antenna is broken.
console hinge limit is not connected.
the garish on the hardtop is beat/broken/missing.
Need to remount my 120V outlet in my new plywood inner rear Q pannels.
need to go to chevy 1/2 ton springs in the back
assemble my axle for SAS.
The rest I can live with.
leiniesred is offline
Old 11-22-2004, 01:51 PM   #87 (permalink)
DrummerDaveB's Avatar
Front O2 sensor is bad.
Armrest mount is cracked.
Rock chips on the hood.
__________________
www.SpartanLeathers.com
98 4Runner SR5: 3.4L, 2WD, Auto.
Also own:
07 Camry
03 Yamaha R6
DrummerDaveB is offline
Old 11-23-2004, 03:09 PM   #88 (permalink)
Ilovemountains's Avatar
Exclamation Hey!
Quote:
Originally Posted by TRunner
The only thing that is 100% broken on my truck is the digital clock. And the factory wants like $300 for it. Being that I get these free in cereal boxes I am managing without one for now. Maybe if my head unit breaks I will replace it with one that has a clock on it...
Ive got one out of a 92 you can have if it will fit, let me know!
__________________
88 3.0 XCab, K&N fipk, Borla cat-back,Magna Flow Cat, Downey frame brace, Downey 2" rear springs, BJ spacers, Aisin manual hubs,B&G Fiberglass bed, extended diff. breathers, Bilstein HD shocks, Rancho RS5000 stabilizer, Brembos & TRD Pads, Revos, Hella 500s, 4 runner bucket seats and console ETC ETC...
Ilovemountains is offline
Old 11-23-2004, 03:11 PM   #89 (permalink)
you can SEE THROUGH MY BED, oh sorry for yelling YOU CAN SEE THROUGH MY BED, did I mention that YOU CAN SEE THROUGH MY BED
__________________
Old 11-24-2004, 11:47 AM   #90 (permalink)
Arrgghhh
I was filling my truck up this morning and noticed that another hole has opened up, this one is in front of my wheel all the way at the front of the bed! YOU CAN SEE THROUGH MY FREAKING TRUCK Thats OK because my fiberglass bed is Finally finished, so this spring it will look good as new
__________________
Old 11-24-2004, 12:13 PM   #91 (permalink)
Send a message via AIM to Mudfreak
speedo and odometer doesnt work, reverse gear is out, small parts of surface rust. everything else is functional, though most of the dash is torn up lol, oh and the rear passenger side bed is messed up. Oh and it leaks oil at the front of the block.
__________________
1989 Toyota Hilux Surf 4x4
1981 Toyota truck 4x4 22R - Gone but not forgotten.
Mudfreak is offline
Old 11-24-2004, 12:13 PM   #92 (permalink)
PoBoy's Avatar
Nothing Well I take that back...I could use some new wiper blades
__________________
So I sold my '96 4Runner to get married...I was sad. BUT NOT ANY MORE!
Check out my 1985 4Runner with 32,xxx miles!
PoBoyTech.Net
PoBoy is offline
Old 11-24-2004, 12:46 PM   #93 (permalink)
mostly maintainance issues:
I think my slave cylinder might need to be replaced or the clutch needs to be adjusted
I got warped my rotors (will replace in near future)
my defogger in the rear window does not work (does anyone know how to fix this)
__________________
Carsten
99 4runner SR5 4x4 5spd
Roadtripr is offline
Old 11-24-2004, 01:07 PM   #94 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
I've lots of scratches on the truck due to very very narrow trails here in Spain.
I've smashed rear bumper due to that (And lose the mud flap):
My AC radiator was bored that summer, I broken the power antenna in a car wash.
I also broke the exhaust pipe, and later welded and trimmed it.
And I think that is all...
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler Auto – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35's, FR&RR E-Lockers and too many things more to write...
Blizzard is offline
Old 11-24-2004, 01:41 PM   #95 (permalink)
hospersc's Avatar
Front Driver CV axle going out.
Noisy and ticking engine.
Leaking Oil Pan.
Leaking Rear Main Seal.
Dent in the Rear Driver Side Below Window. (First dent is always the toughest)
Broken blinker housings in front.
Dented bumpers.
Gotta love it.
__________________
1994 Runner, 32" Mud Kings, Downey 2", Rancho RS5000's, Rock Solid Sliders, Manual Warn Hubs, ARB Rear Air locker, AeroTurbine Muffler, Yakama Roadwarrior, 2 Hella 500's, $10 NAPA Special rock lights.
_____
hospersc is offline
Old 11-24-2004, 02:17 PM   #96 (permalink)
rah1420's Avatar
Send a message via AIM to rah1420
Won't start if it's really, really hot when I shut it off (probably bad starter, might be just the contacts.) I tend to drive it on errands where I don't shut it off, or I drive it a lot and let it sit for 8 hours (like to work.) If I drive it to the grocery store, I'll be turning the key and clicking for half an hour before I get rollin' again.
I had a CEL but I never pulled the code.
Last time I drove it I didn't have the CEL but now the damn thing is blowing EFI fuses, and won't run... so I'm mining the Yotatech knowledge mine to figure out what it might be. O2 sensor, maybe.
If I could only get it goin' I'd go up to Paragon and have some fun but I don't dare take it up there like this.
__________________
'91 4Runner (Basic Black) -
Driveline stock - 3.slow V6, 4.56 rear, 31" shoes
Cobra CB,Firestik antenna
rah1420 is offline
Old 11-24-2004, 05:37 PM   #97 (permalink)
Bluedog's Avatar
Knock wood. 47000 mi and nothing.
__________________
2005 Tundra: iForce V8 4WD
American Racing Teflon Mojave's. Pirelli Scorpion ATR LT 265/75 R17
1995 FZJ80: OME 2.5 heavy, Borla Cat Back, 16",
Wheeler's 16 Black Alloy Wheels, Revo's LT 285/75-R16, Slee Rear bumper, Slee Sliders, TJM Front Bumper, Custom Rear Drawer System, Center Diff Lock & Seven Pin Mod.
2007 Subaru WRX STI. Borla Cat Back, Momo Shift knob, Injen CIT
Bluedog is offline
Old 11-25-2004, 10:29 PM   #98 (permalink)
White83's Avatar
Only two things that I know of are wrong with the truck...
- backup lights don't work due to a wire that is broken
- the front mount for the driver's side of the bench seat has a broken away from the floor, just needs a couple of welds to fix it.
White83 is offline
Old 11-25-2004, 11:35 PM   #99 (permalink)
My '89 Toyota has been with my family since it was new and in the 170,000 mi. since all that has really been wrong with it was a faulty head gasket that was covered by a factory recall on the 3.0 V-6. Have had the bushings wear out on the shifter and have replaced a stolen tailgate. Right now the only thing wrong with it is the lever to push the seatback forward.
__________________
1989 Toyota 1-ton Pickup
3.0 V-6, MT
200,000 miles and counting
1tonMike is offline
Old 11-25-2004, 11:38 PM   #100 (permalink)
ianshoots's Avatar
I just got a new upstream O2 sensor and I had my brakes done (majorly warped rotors)-you don't know how bad your brakes are until have new ones, amazing!
So nothing major.
-I have a broken leaf in the back, but its okay cause I want new leaf springs anyway.
-I'm told by my mechaninic that after they cleared the code for the o2sensor the system flashed a new one; Low enging temp, which translates to needing a thermostat. Will probably do that myself.
Nuttin else, 163K and runnin strong!
__________________
BOUGHT BACK AND CRUSHED: 97 3.4L Tacoma; Borla cat-back, 4" Deckplate, Amsoil foam air filter. Black Raider high rise cap w/Yakima bars. ebay Nerf bars. ARB bullbar w/Lightforce 170's on it and a Warn XD9000 in it, scratches. Tundra Coils W/Anders Eng Spacer, OME's, Wheelers 5 leaf pack , Sonoran Steel Diff Drop and some '01 Celica seats!
Missed...
ianshoots is offline
Tags
4runner, 91, axle, broken, celica, cv, differential, fill, front, plug, rear, rot, toyota, trac, transfercase, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
A/C is broken Shirleyda4runner 95.5-2004 Tacomas & 96-2002 4Runners 9 08-14-2007 08:03 AM
What have you broken??? apalmer1 Off Topic Talk 10 04-12-2007 09:44 PM
Exactly how can I tell if my cv is broken wailukutoy 86-95 Trucks & 4Runners 8 04-11-2006 06:41 PM
just broken in motoracer47 Off Topic Talk 1 09-12-2005 09:17 AM
HELP! broken? Short1 95.5-2004 Tacomas & 96-2002 4Runners 12 01-24-2003 04:26 PM
2009 InternetBrands, Inc.
