| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
#27 (permalink) | |
Quote:
#28 (permalink) |
my 4runner needs a whole new paint job, i have bondo cracks on the driver, who ever did the body work and paint job did a terrible job, my driver side window wont roll up or down, my rear bumper is loose, my hitch rattle against my bumper, my rear window hardly roles up, i need a new motor for it. i think thats everything, but with all that i will drive my toyota until it dies.
__________________
anything other than a toyota, would be uncivilized. 91 4runner, 4" tuff country lift, with a 2" tuff country body lift, k&n intake, 2.5 inch high flow cat and flowmaster exhaust, 33x12.5 thornbird's and a loud system, future mod's:: lower gears and lockers. |
#29 (permalink) |
See here that's what's "broken" on my truck. I wouldn't go as far to say that they are broken, more or less really really worn down.
#30 (permalink) |
Here's what's wrong with my 4Runner:
-small dent in the drivers side door -oil leaking from valve seals -a/c just broke not sure what is wrong yet The only thing that's going to get fixed probably is the a/c. The oil leak will take too long fix and I can't afford to have my 4Runner disabled for the amount of time I'd need to fix it. The dent adds character! -Keith |
#31 (permalink) | |
Quote:
__________________
Milton 01 Tacoma access cab 4x4 TRD TC Long travel, Supercharged 04 Tacoma Doublecab 4x4 TRD hoes all around! |
#32 (permalink) |
Guest
Well today while showing off parking at a buddy's shop in an extreme angle and pulling the Ebrake it snapped. So thats the latest. My K & N is dirty giving me chittier GM than usual and sluggish acceleration/needs cleaned. My rig is hella dirty and needs detailed but not until it stops snowing/raining. Oh and my TXR tires are not beefy looking enough so I need mud terrains tires of some sort. Oh and im tired of the alloy look and want black rims. Nothing really is wrong with my 4runner as much as the Ebrake but some stuff gets to me. Not like your rust issues though, that just sucks arse Lamm. BONDO!
#33 (permalink) |
maybe we should
__________________
#34 (permalink) |
One of my leaf springs broke 2 weeks ago on my 92, and my 86 is going to need a timing chain(making noise for a while).Easy fixes
#35 (permalink) | |
Quote:
When leaf springs break, do they actually break as if you were to break a pencil? |
#36 (permalink) |
left front tie rod, brakes, headlights, speakers need to be replaced, drums need to be surfaced, windows need to be re-tinted do to peeling and scratches, need to figure out what to do with my peeling paint problem, repaint it or take it down to metal, prime it and then get some 3m Camo Wrap? need to clean my throttle body, maf sensor, need to replace the exhaust, o2 sensor, right front side light doesnt come on unless i tap it, but once i hit a bump its off again, flares are cracked and not wide enough and need to be replaced, need to get some new gaskets i think for my shifter, need to replace the clutch pedal bracket or spacer.....and im sure by the time i get all of that done, not in that order, i'll have another list just as long
__________________
DJ 1994 Pickup 22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around... Preping for SAS...... Originally Posted By Fustercluck "Proof that Gangus did not spontaneously generate....he has relatives." Originally Posted By Tacoclimber "My two year old better get a job, soon..." Reply Posted By Oly884 "I hear coal mining is a great career." Myspace |
#37 (permalink) |
Nothing mechanically broken just minor annoyances like the CD player skipping over bumps and one front speaker occasionally cutting out.
I have a strange clunk/rattle sound from somewhere under the truck that has yet to be diagnosed. I know it's not the spare making noise and it doesn't happen very often. :cry: |
#38 (permalink) |
__________________
Ryan New: 2008 4Runner Sport. Mild, not wild. Old: 2000 4Runner 305s, Locker, TJM, Warn, Skids, Sliders, SC |
#39 (permalink) |
funrunner,
with regards to your clunking noise, does it only happen when you go over speed bumps? only hear it from the rear axle? do you have a rear hitch? if so, theres a piecein the rear hitch that is making that noise. my service manager knew exactly what it was, crawled under it, moved some part and that was that. ![]() bob |
#40 (permalink) | |
Quote:
Anybody else have this problem? Other problems: - The annoying "tick" - Steering fluid leak - Rattle noise coming from driver's side front suspension. Sounds like something is really loose when I drive down a washboard road, but I can't find the cause - Cable on gas cap lever is frayed and about ready to snap. How hard are those to replace?
__________________
Kevin 2004 Infiniti G35 Coupe 1998 Toyota 4Runner Limited - Sold Deckplate Mod, Rear E-Locker, Anytime Locker Mod, Commando FM-870, 2 1/2" Lift, 285/75R16 Bridgestone Dueler Revos Kenwood XXV-01D, Sirius Sportster Replay, Memphis 16-ST500D, Rockford Fosgate 4.6x, Image Dynamics IDQ-12, CDT EF-61i Last edited by jimrockford; 02-05-2004 at 08:59 PM. |
#41 (permalink) | |
Quote:
I do have a hitch but still can't pinpoint where the sound is originating. I've felt around to see if I can find anything loose but no luck yet. It's not just over speed bumps but over some bumpy, uneven roads.If I take it to the stealership I know it wouldn't dare do it for them. Next oil change maybe I'll ask them about it, otherwise the search continues........ Thanks for the idea! |
#42 (permalink) |
funrunner,
try this test: go to an empty mall in the evening and go over some speed bumps. vary your speed until you hear the sound. my rear clunking sound only came from the rear axle. try it and if that is the case, put some gloves on and poke around the main supports for your hitch. if i can take a pic tonight, ill post it. bob Last edited by Bob_98SR5; 02-05-2004 at 09:09 PM. |
#43 (permalink) | |
Quote:
![]() Thanks again! |
#44 (permalink) |
Lets see:
Power antenna doesn't budge, gears stripped. I dont use FM anyways (XM ONLY) Stupid plastic handles on the heat controls always pop off. Misc rattles in the rear (possibly from subs) Nothing mechanical tho! (shhh!) And oh yah..its missing a lift, and a locker. Go figure!
__________________
2008 Mini Cooper |
#45 (permalink) |
"Its a 33 year old Landcruiser for crying out loud.
Rust issues below both doors and floor. Transmission filler tube. Finish rebuilding the front disk axle and "get er Done!" (remove drum brake axle) Remove aux tank (rusted out) Replace fiberglass roof (have parts) Replace windshield and frame (have parts) Finish the bucket seat install Repair rusted out glove box" Hehe, hello North Bend WA.... Crescent City here. with a 68 TLC. Still running good, but the rust is raising its ugly head more.... not to mention the World Famous drum brake nightmare..... as mine sits for 6 months at a time while Im in Alaska with the Tacoma (my other Toy)...
__________________
02 Taco 4x4 Extra cab now joins my 68 TLC Ive owned since new. Wanna talk about Toy reliabilty??? |
#46 (permalink) |
-Running-board end cap came off in car wash (now dealer's saying that the RB looks like it's slightly bent and I should just order a whole new one -- lookin like it'll cost 400!)
-Some moisture got into one of the headlamps and so it shorted it and I'll need a new one. -One of the rear windows will lower but will not raise (it's up now thank God) so a master switch needs to be ordered and then installed (another 400 bucks).-Tiny dings here and there that will be easily removed (barely noticeable) -Tempermental keyless entry fob, dunno what's its deal. It's kind of generic and was installed at the original dealer so I guess I'll have to just install an aftermarket alarm sooner or later. -The speedometer needle seems to wiggle for the first ten to twenty miles per hour. Maybe I'm just nit-picking here, but it's something I noticed. -Roof rack and rear air deflectors have faded a bit. Rest of the car looks real good, though. -Oh, yeah, and one of the rear door handles is starting to have it's chrome "sticker" bubble a little bit. It's not rust, just starting to come loose I guess. |
#47 (permalink) |
Everybody has something wrong with their rig, at least I'm not alone
For my 89 w/190k the only things wrong are that the digital clock isn't working, and my A/C needs to be recharged (will get done for summer) And if you consider rubbing to be a huge issue as well...
#48 (permalink) |
After 205,000 miles-
Small crack in the dash over gauges. Rip in the leather of drivers seat from entering-exiting. Recliner handle of the drivers seat is off. These things were like this when I bought it and I consider to be minor. No rust, no bad paint, no dents, no oil leaks etc. Everything mechanically/electrically works.
__________________
Chris Mine-94 SR5 4-Runner, 3.0, 4X4, Aisin Hubs, Yakima Load Warrior, 210k Miles | Wifes-99 Limited |
#49 (permalink) | |
Quote:
#50 (permalink) |
mauiwowie, $400 to replace a switch? Sounds like you need to find a new dealer. Thats outrageous. Go to a junkyard and get one or take the one you have apart. The switch comes off with the interior panel and can be replaced in less than 5 minutes.
The switch that rolls down my back window got soda in it. I took it apart and cleaned it. Very simple if it is the same style switch. I think you said you had a 2nd gen the other day. If so the headlight can be fixed by replacing a $10 bulb. The whole unit can be removed and put in a warm (not hot) oven to remove the moisture inside. Remove the bulb and put the whole assembly in a 150 deg oven for 20 minutes. All the moisture will be gone. I have done this many times after driving through deep water.
__________________
| Tags |
| 4runner, 91, axle, broken, celica, cv, differential, fill, front, plug, rear, rot, toyota, trac, transfercase, water |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| A/C is broken | Shirleyda4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 08-14-2007 08:03 AM |
| What have you broken??? | apalmer1 | Off Topic Talk | 10 | 04-12-2007 09:44 PM |
| Exactly how can I tell if my cv is broken | wailukutoy | 86-95 Trucks & 4Runners | 8 | 04-11-2006 06:41 PM |
| just broken in | motoracer47 | Off Topic Talk | 1 | 09-12-2005 09:17 AM |
| HELP! broken? | Short1 | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 01-24-2003 04:26 PM |
