Way to reduce gap on hi-lift jack mount?
Anyone know of a way I can keep my hi-lift jack from sliding back and forth in my roof rack mount? The mount is about 3" wider than the jack and the jack slides back and forth ask I drive. I was thinking of putting in rubber blocks, but I can't find anything like that.
I'm not sure if you can see in this picture, but the mounts are way wider than the jack bar.
I would look into wrapping a cable with a lock around it and the rack for security and the movement issue
Just looked at the mount pics, easy fix is to cut tubing for spacers
Just looking I could think of a dozen different ways to do that.
What were those brackets made for ??
Even pieces of Nylon or ABS plastic that most any industrial supplier stocks .
I buy things like that from McMaster -Carr because the Brown truck brings it.
Cheaper then I can drive and hunt for things.
arlindsay1992
11-16-2016 03:45 PM
