Turn key.... but engine won't turn over ...sometimes! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-16-2006, 04:52 PM   #1 (permalink)
FLArunner's Avatar
Cool Turn key.... but engine won't turn over ...sometimes!
Sometimes she starts, and stalls immediately after start-up. Other times, I turn the key and the dashboard lights up, but the engine doesn't crank at all. Usually, when she's cold. Oher times, she's fine. No codes showing up when the computer was hooked up. New timing belt recently. Any help is appreciated. A mechanic, I ain't. But if I follow the Hanes manual, I can do most jobs.
FLArunner is offline
Old 10-16-2006, 05:14 PM   #2 (permalink)
rdharper's Avatar
Quote:
Bad contact somewhere. Can be mechanical or electrical. Ignition switch, starter relay, ring gear with a bad tooth or two.
If you hear nothing when it does not start, meaning no cranking, and no click (the starter relay), then it may be the ignition switch or the starter relay. If you hear a click, but no cranking, I'd suspect the starter motor, assuming the battery is ok.
__________________
Richard
"Science by consensus... is not Science." Richard Harper -1988
'94 Toyota 4Runner V6 3L 158K miles 14mpg
'85 Toyota 22rec 4WD SR5 LB PU 208K miles 18mpg
'08 Honda Ridgeline RT 4.8K miles 16mpg
'06 Honda Rincon ATV 410miles/65hrs 22 mpg
rdharper is offline
Old 10-16-2006, 05:23 PM   #3 (permalink)
FLArunner's Avatar
Thumbs up Thanks, Rich.
I tested the batt., and it was good. Turn the key, and no clicking or turn-over whatsoever. I'll look further into your suggestions - thanks for your help.
Old 10-18-2006, 06:22 PM   #4 (permalink)
FLArunner, I actually just had the same issue with mine.
I changed the batt and all of that and ended up having to change the starter.
I got it back from the shop a few hours ago and it seems as though I'm still having issues....
Now the engine seems like it is about to stahl and I need to gas it so that it doesn't. Also, the exhaust is kicking out some smoke and is more odoriforus than normal
Any suggestions from anyone?
lowmaintenance is offline
Old 10-18-2006, 06:47 PM   #5 (permalink)
lee
Send a message via AIM to lee
i am having this issue, but it always eventually turns over. only hasnt started up twice, and both of those times it started on the 3rd try
im gonna put in a new starter, though its likely the contacts
lee is offline
Old 10-18-2006, 06:50 PM   #6 (permalink)
My problems started right after replacing the timing belt/ waterpump. Just like you lee, it would eventually turn over after a few tries but then one day...she only gave me a click, nothing else.
Old 10-18-2006, 07:08 PM   #7 (permalink)
fireteacher's Avatar
start cheaply with the starter contacts. no real need to buy a new one, i made that mistake. search around the forum, there is a write up somewhere.
heres a good write up for it
http://www.4x4wire.com/toyota/maintenance/starter/
__________________
Shaun
99 limited 4runner 3.4L
MODS: TJM-17/Sonoran shackle hangers/driving lights - DIFF Breather - Sliders - Cobra 19 ULTRA III cb and 3ft. Wilson ant - 265/75/16 Definity Dakota A/T - "SATOSHI MOD" - All Weather Mats - Locker Mod - Fog Light Mod - Vortex Classic Muffler
My profile http://yotatech.com/showthread.php?t=96117
fireteacher is offline
Old 10-14-2008, 10:01 AM   #8 (permalink)
kev
kev's Avatar
connections between batt. and starter (check for loose / corroded wires) Also check Batt. ground. Kev
kev is offline
Old 06-14-2009, 09:42 AM   #9 (permalink)
Island4Runner's Avatar
im having this problem too...got power but it wont turn at all.
Island4Runner is offline
Old 06-14-2009, 11:00 AM   #10 (permalink)
ETRNL's Avatar
wow i thought i was the only one having this problem... everytime i turn my key though i hear a click, so i know it is the starter contacts. i already have new ones just waiting on time to tear it down.. local alt/starter shop had the contacts for $5 a set so $10 dollars and she will start everytime again!
__________________
2001 4Runner LTD, ISR/deckplate/ECT mod, 90w/130w Hella headlights, 12g headlight wire harness, Satoshi, Hood Emblem, fog light mod, constant power mod, big 3 mod, NO DRLs, Remote start with ~1 mile range, Toytech OMERun-3 3" lift, Big Foot ATs 265/75 R16. True Flow air filter, Aux reverse lights
my favorite video
ETRNL is offline
Old 08-23-2010, 05:27 AM   #11 (permalink)
Hoopster's Avatar
My 4runner has just developed a similar problem. It has a fairly new battery and I also tried cleaning the terminals and chassis ground.
I don't think I'm getting a click when turning the key (I'll have to check when I get home) although the dash lights do light up.
It will eventually start but sometimes requires quite a few tries.
Does this sound like a starter relay or starter contacts?
Hoopster is offline
Old 08-23-2010, 08:53 AM   #12 (permalink)
4Crawler's Avatar
Easy way to check out what the problem may be:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-23-2010, 09:08 AM   #13 (permalink)
Hoopster's Avatar
Thanks for the link. I think I ran across it early and it seems to be one of the better places to start. I guess I'll get out the multimeter and start digging around this evening.
Hoopster is offline
Tags
4runner, 93, clicking, engine, ignition, imediately, key, motor, small, start, times, toyota, turn, turning, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
turn key once wont try to start try secound time it will marke 95.5-2004 Tacomas & 96-2002 4Runners 3 02-12-2006 07:03 AM
key or ignittion problem..cant tell which.. but cant turn key sabre Maintenance & Repair Archives 3 06-27-2005 11:28 AM
If I turn my key and i hear a click and no engine turning????? don_davi 95.5-2004 Tacomas & 96-2002 4Runners 14 02-07-2004 07:13 AM
Turn key --> click! Turn key again vroom!! My99 95.5-2004 Tacomas & 96-2002 4Runners 34 11-16-2003 09:24 AM
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
