| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Truck Won't Start
__________________
'85 4Runner DD Anti-sway mod/Diff Breathers/XRC 8000 Winch/Smittybilt All Around/4 Wheel Disks/Custom intake/2.5" exhaust/Custom Stereo |
#2 (permalink) |
22R? RE? You did the bottom end only? Engine in truck? Check all grounds, fuel pump, plugs are plugged in, all spark plugs plugged in, and connected correctly to the distributer, timing correct, distributer not off a tooth or two. If all you did was pull the oil pan and work on the bearings from under there...how long was it down for? Sometimes my truck (carbed) will take a long time to start after sitting for a bit. I think the gas is draining back into the tank or something...but if I crank it for a while it will start. More info will help.
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
#3 (permalink) |
it's a 22re in a 4runner
It's not ignition, timing, or the fuel pump the problem is the engine isn't turning over, like it's stuck somehow. I wasn't able to move it at all by hand when i was working on it. It sat for a few weeks while I was working on it. The starter turned it half way slowly; something seems tp be proving heavy resistance to the crank or cam
__________________
#4 (permalink) |
OH. So that's weird...it ran fine, then when you had things pulled apart, you couldn't turn it by hand? Well, not knowing exactly what you did and didn't do, it's pretty hard to say. Did you just drop the oil pan and replace the bearings? That's it? I can't think of any reason why it wouldn't turn.
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock Last edited by 83; 10-15-2009 at 11:30 AM. |
#5 (permalink) |
Did you take the rod caps off?
Did you drop the crank? That is, take the rod caps off. It sounds like you put one or more rod caps on twisted around. I can't understand why you would do a bottom end without doing the rest of the block. If you had a bad main bearing, you probably have other problems with the engine.
jrohland |
#6 (permalink) |
The bearings we're fine; someone told me I should change them to get the full benefit from switching to a full sythetic oil. Wasn't really a big deal, except for now. I'll drop the pan here in a few and check the rod caps.
One thing I realize... I had the engine jacked up at the tranny to get the clearance to pull the oil pan... I still had it jacked up when I torqued the main bearing journals back down, I'm thinking it's binding at an angle because of that... which I'll also be checking when I drop the pan here in a few
__________________
#7 (permalink) |
Sure the bearings aren't too tight? Loosen them up a wee bit and I bet you can turn it by hand then.
__________________
"""The Official Unofficial build thread!""" 92 std cab 22RE 5 spd 4x4 268 Engnbldr Cam 3"Intake w/ cone 31X10.5----4.10's Purchased 11/08 @125K miles Great find first project Toy 95 SR5 4Runner 3.Slow Auto :-( 4x4 (5 spd someday) 33X12.50----4.88's LC Coils She's raked a bit now 5/09 Traded a 1980 CB 750 for it!!! Yeah for me... 106K miles IFS Club #2 |
#8 (permalink) |
I couldn't turn it by hand when all the bearings were loose before
__________________
#9 (permalink) |
You should be able to turn the motor over with a moderate breaker bar.. Did you plastigauge your bearings?
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#10 (permalink) |
Tried both my 17" breaker bar and I surpassed 150lbs on my torque wrench.
Plastigauage came back within spec
__________________
#11 (permalink) |
so i found the problem... it's Rod #2
plastigauge has it at less than .025 with the new bearings... I tried a pair of the old bearings and it still stuck any ideas on what i should do?
__________________
| Tags |
| start, truck |
