Trouble Turning Crank - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-06-2009, 01:54 PM   #1 (permalink)
forwardtocharis's Avatar
I'm in the process of changing out my engine bearings with the crank in.
I've been having trouble getting the upper main bearings in. I had loosened up all the main bearing journals and then read that using the oil feeder hole on the crank with a cotter pin was a good idea. This requires turning the crank.
If I remember correctly from changing my head gasket, the crank was not all that difficult to turn. I think I did it with a 3/8 ratchet last time.
This time, I maxed out my 150 ft/lbs torque wrench and then switch to my lighter, 18" breaker bar. I was able to move it a tiny bit, but not enough to help (just a couple of degrees).
Obviously the oil has been drained, but I can't image that is the problem
The journals are all still loose.
I don't want to keep cranking on it like that, something doesn't seem right. I also put both the transmission (5-spd) and the t-case in neutral. I can't think of anything else, so I'm hoping you call can help me, it's already been too long since I've driven my truck!
Thanks!
__________________
'85 4Runner DD
Anti-sway mod/Diff Breathers/XRC 8000 Winch/Smittybilt All Around/4 Wheel Disks/Custom intake/2.5" exhaust/Custom Stereo
forwardtocharis is offline
Old 10-06-2009, 02:03 PM   #2 (permalink)
camo31"10.50"'s Avatar
i had the same problem when i first got my 22r rebuilt...but now i cant remember what the problem was.....
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE
1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous
"Its still a toyota man.. Dont deprive it of its capabilities.."
"If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009
camo31"10.50" is offline
Old 10-06-2009, 04:59 PM   #3 (permalink)
I've poped off all the spark plugs to, in case the pressure from inside the pistons was the problem, still no good :/
__________________
'85 4Runner DD
Old 10-06-2009, 08:22 PM   #4 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Stupid question maybe, but do you have the trans in neutral?
Crap, nevermind, you said it was.
(there needs to be a delete post button)
Adam F is offline
Old 10-07-2009, 07:56 AM   #5 (permalink)
Yup, it's in neutral,spark plugs out, won't hardly budge
Anybody?? I really need to get this done
__________________
'85 4Runner DD
Old 10-07-2009, 10:05 AM   #6 (permalink)
Adam F's Avatar
Could the bering journals be binding since you loosened them?
Adam F is offline
Old 10-07-2009, 10:47 AM   #7 (permalink)
I'm not entirely sure what you mean... none of the journals are touching the crank at this point.
I have my first upper bearing about 1/4 of the way in (as far as I could get it by hand), it's in the number 2 journal.
I'm replacing the old bearings with standard size bearings, the pastigauge head read about .05 across the crank, which is within standard tolerance.
__________________
'85 4Runner DD
Tags
350, binds, crank, crankshaft, rebuilt, transmission, turning, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
