| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Location: I live in Red Bluff ca. Right by the Sacramento river
Timing Problems
__________________
When you stop seeing Jeeps and Fords, and start seeing Mountian Goats and Toyotas, youre in the holy land that only we can get to. Gotta Love It!! |
#2 (permalink) |
http://s492.photobucket.com/albums/r...ruck%20videos/ heres a vid of how it ran after I put it back together from those pics. I dunno whats wrong, maybe its possible it jumped a tooth? Im lost.
__________________
#3 (permalink) |
Are you starting from scratch with the crank at TDC and number one piston firing? To verify you can pull the plug on number one and carefully stick a screw driver in the spark plug hole and make sure the piston is TDC by having some rock the crank pulley back and forth slowly. The mark on the harmonic balancer should be at the zero mark on the timing tab. Before you poke the disty in, turn the rotor so it is about 12 degrees from the number one firing on the cap. As it slides in and meshes with the gear on the cam it should turn slightly and line up so the rotor contact is sitting at the contact on the cap. You can make a little mark with the cap on before you do this. You should have the bolt hole so it's about in the middle of the slot on the disty. You may have some spark plug wires crossed. Re-check the firing order. It doesn't sound like it's firing on all four. You may have some bad spark plug wires. What's the condition of the spark plugs?
gNARLS. Last edited by Gnarly4X; 11-02-2009 at 10:18 AM. |
