| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Synthetic or Not!
__________________
Your only lost if you admit it! '00 4runner SR5 4wd V6 (no mods yet) '97 Tacoma r-cab 4wd 2.7L Other toys-'05 Honda foreman 500 4wd (my ride) '00 Polaris magnum 325 2wd (wife's ride) |
#2 (permalink) |
I don't know about the saying with if it's never had synthetic, then don't put it in, but I have heard that once you go synthetic, you shouldn't go back to regular oil.
That being said, I run Mobil 1 in my truck since the guy I bought it from (a Toyota nut) has always run Mobil 1 in all of his Toyotas and never had a problem. I guess stick with what works. Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s |
#3 (permalink) |
Just make decision...there is no recourse if you get the "wrong" information off the internet. You will have people tell you they've ran synthetic with no problems and mineral oil with no problems. If you change it every 3k odds are it doesn't really matter.
http://www.dezmo.com/oil03.html http://www.dezmo.com/gordononoil.html http://www.dezmo.com/dezonoil.html http://www.bobistheoilguy.com/
__________________
2000 4Runner Limited 4WD Millennium Silver Toyota OEM NAV OME springs/shocks F/R VZN185L-GKPZKA 4.300 With P265/70R16 |
#4 (permalink) |
Some facts about synthetic oil:
- if you have leaks, synthetic will tend to make them worse - if your engine is very worn, synthetic will not help much - if your engine is not worn, synthetic WILL reduce the amount of wear - synthetic is more expensive - you may want to consider getting a filter re-locating kit so you could use a larger filter. - you should be able to extend the OIL changes to 10K, if you change the FILTER every 3-5K (providing it's a bigger filter). This can make up for the extra cost of synth oil. - it will take several (3-4) oil changes of synthetic to fully "flush" your internals to full synth. Having said all of this, the move to synth depends on the intent for the vehicle. If you trully intend to keep the vehicle for an additional 100K miles, and if the engine isn't worn (under 100K) currently, then synth may be a good choice. I have run synthetic oil in all of my vehicles, including my race-cars ('72 Datsun 240z), and will continue to do so.
__________________
Gettin' out, for now... |
#5 (permalink) |
Many threads on this and many different opinions scattered throughout this board. I switched right before 100k to synthetic b/c I don't drive more than 10k miles a year and wanted to do preventative maintenance once a year.
I'm about five months into this and will let you know by the end of the year if I've had any issues. So far, so good. BTW, I also swapped synthetic into the auto tranny and diffs.
__________________
____________ Edwin 1999 SR5 4unner |
#6 (permalink) |
I switched my Runner over at 96k when I bought it and no problems but if it had another 100k on it I would've just stuck with dino oil.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#7 (permalink) |
Thanks everybody!
I was just wondering. I've got a few quarts of valvoline left from the case I bought a few months ago. I'll probably use it this time then maybe check into Amsoil, because I got a friend that can get it. he runs it in his ATV.
__________________
#8 (permalink) |
I always run sythetic in my rigs. I switch my current truck over at 150K. No issues. I go so far as to use synthetic grease on u-joints and wheel bearings. They are a far superior product. If you run the larger filter and change it you can got 25K on Amsoil products. Throw a by-pass filter in and your oil will look almost new at 25K. Defenitally better on the engine, and can be cheaper over the life of the rig.
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's... 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#9 (permalink) |
[quote=uberhahn]Some facts about synthetic oil:
- if you have leaks, synthetic will tend to make them worse - you should be able to extend the OIL changes to 10K, if you change the FILTER every 3-5K (providing it's a bigger filter). This can make up for the extra cost of synth oil. QUOTE] Hogwash! That whole leak myth is just that; a myth. Don't change the filter between oil changes, that's stupid. Just use a hi capacity premium oil filter (WIX, OEM, etc). And if it takes you a year put 10K miles on your odometer, then don't do a 10K mile oil change interval. Make it 7K or so. You can't have a free lunch. If you don't change your oil for a year, regardless of oil type, you're not maintaining your vehicle properly.
__________________
'03 beauty of a white Tacoma, check it out: http://www.yotatech.com/f83/spindles.../#post50606613 "The fingers you have used to dial this number are too fat. For information on how you can obtain your own personal dialing wand, please mash your palm against the keypad now." |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) | |
[quote=spindleshanks]
Quote:
Check this page out. It has the recceommend drain intervals for Amsoil. The oil I use says 25,000 miles or 1 year, whichever comes first. Synthetic oils are different, they dont break down like conv oils. I only change my oil once a year. And even running a much larger filter I still change it every 5K. A new filter never hurts. When I get my by-pass installed I will change the full flow every 5K, and the by-pass every 10K (which is about 1 year on my P/U).
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's... 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. Last edited by AH64ID; 05-19-2006 at 08:45 AM. |
#12 (permalink) |
If you don't believe that synthetic is better then stay with what you have. I'm old enough to remember when good oil was good oil and the only argument was which one was the best. They were all good but then they went to hell in a short time.
Now I feel that there is no way you can beat synthetic oils and I believe that Mobile 1 is just as good as Amsoil. Before you switch get a couple quorts of the engine flush they all sell and do it right. As for how often you should change it I can tell you that I go 8,000- 10,000 miles before I change the oil or the filter. I do change the air filter about every 2,000 miles because that's about how long I go before greasing my Tacoma and I drive in some dusty areas as well as a lot of stream crossings . Mobile1 has now come out with a 75,000 mile oil and I'm sure Amsoil has one they claim will go longer. The Idea that you have to change your oil every year is just silly but it's fine if you want to do it. Oil does not break down sitting in an engine anymore than it does sitting on the shelf. What makes me change my schedule of 8,000-10,000 miles is what kind of wheeling I have been doing. If it's off road hot dusty weather then I will change it sooner.Can't say that I have to, Just makes me me feel better. Been doing it this way for a few years now and have no leaks and it purrs like a kitten. Must be doing something right
__________________
2001 Tacoma SR5 4x4 , step side, 2.7 , extended cab, Auto. Mobile 1 syn 5w30 , Valvoline 75-90 syn in front and rear diffs and transfer case. Factory 16" wheels ,31" Wild Country TXR 265/75/R16, Aluminum Betterbuilt bed tool box, CB , 55W Halogen light mounted on tool box for back up, Elbow air box mod, 2 500 Hella running lights, Nissan Clinometers/Altimiter custom mounted on dash with red back lights.Red dome and mapp light. |
#13 (permalink) |
Sadly, nobody is right all of the time. I'm afraid it's your turn, spindleshanks.
Dino oil will expand oil seals and gaskets, while synthetic oil will not. I has nothing to do with viscosity. I speak from personal experience with my own leaky vehicles, in addition to my profession in the automotive industry. If your oil is "clean" - low particulate count, while maintaining it's viscosity, changing the filter only is a perfectly viable maintenance method. There are bypass filters on big-rig semi trucks that use bypass filters with entire paper-towel rolls as the filtering element, extending the oil change interval significantly. A little research goes a long way...
__________________
#14 (permalink) | |
Quote:
__________________
#15 (permalink) |
I run Royal Purple and have no problems with it... Been almost a year... and last I checked the oil in the dipstick was light brown...
__________________
2007 Tacoma Double Cab 4x4 TRD Sport 6speed
Pro Comp 6" - Bilstein 5100 front 18x9 Moto Metal 951B - 325/60/18 NTG Pro Comp Skid - Lund Grill Cover 17x10 Weld EVO Velociti 6 *soon |
#16 (permalink) |
What about acidic build up in the oil (longer than 3 months) because of internal combustion by-products. This seems the be a concern for 4-stroke dirt bikes, or is that apples and oranges when talking about trucks??
David |
#17 (permalink) | |
Quote:
hupptoy
__________________
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 165K+ 93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K+ |
#18 (permalink) | |
Quote:
I have had two vehicles with oil leaks that went away after switching to Mobil1. The leaks slowed down after a couple weeks. And, the leaks were gone after a couple months. I 've heard similar stories from others.
__________________
1989 4Runner - 3.0 V6 5-speed, CS144 190 amp alternator, 285/75-16 cheap Dakota tires, Marlin Crawler dual transfercase w/4.7 gears in rear, rear ARB locker, ball joint spacers, hybrid stock/1 ton rear springs, 2" body/drivetrain lift, Budbuilt crossmember and skidplate, Surco roof rack |
#19 (permalink) |
Typically small leakes do contiune to leak, if not grow with synthetic. Not saying this is 100% true, but its due to the viscoticty difference. Usually a leak takes something to block it to stop it, depending on where it is.
Synthetic will not, however, create leaks where they dont exist.
__________________
#20 (permalink) |
i use mobil 1, i love it, longer between oil changes and i j ust feel better about it, mental maybe, who knows
__________________
2006 Tacoma 4x4 TRD Sport with 20's and 285 Goodyear Furtura's and 2 inch cornfed lift 2002 Tacoma Extra Cab V6 (SOLD) |
#21 (permalink) |
I have been using Mobil 1 in all of my cars for years. I do it for longer maintenance and extreme operating tempatures here in Iowa.
__________________
My Profile |
#22 (permalink) |
Here we go again...
Tell ya what... use whatever you want. If you think the reason your oil leaks are gone is the oil, then fine. If you want to keep throwing money away every 3K miles by chaning oil and filter, do it. The reasons for synthetic are many. Oil change intervals are one of them, with the proviso that your filter can handle it.
__________________
#23 (permalink) |
I've been using syn in all my gear boxes, xfers, and diffs. I gained 2 mpg. I also use syn in all drivetrain including the engine in my TR-6. It leaks but it always has, ITS BRITISH. Runs better, shifts better. Petro based oils start breaking down once they hit an operating temperature. Drive it once, park it for 3 months, change the oil. Syns dont break down from normal heat. Acids build up with petro based oils from moisture.
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Opened intake, K&N Airfilter, BFG A/T LT265/70R16, Bilstein Shocks, FreeFlow Exhaust, Poly Rack Mounts & Swaybar Mounts, Tundra TRDs up front and OME 891s out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. ARB rear locker, OBA, CO2 See My 4Runner! Last edited by Gerdo; 05-19-2006 at 06:20 PM. |
#24 (permalink) |
What is the normal time/mileage needed for break-in? (different car)
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Opened intake, K&N Airfilter, BFG A/T LT265/70R16, Bilstein Shocks, FreeFlow Exhaust, Poly Rack Mounts & Swaybar Mounts, Tundra TRDs up front and OME 891s out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. ARB rear locker, OBA, CO2 See My 4Runner! |
#25 (permalink) | |
Quote:
At 10,000 you should be good. Its the number I have always used.
__________________
| Tags |
| 325, dipstick, magnum, polaris |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Changing to synthetic | timk2915 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-25-2005 01:03 PM |
| I'm flaked, but synthetic . . . | 4RunnerFever | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 07-20-2004 03:53 PM |
| synthetic? | Tokez420 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 05-19-2004 04:13 PM |
| I'm Synthetic and more!!! | ugadawg95 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 11-18-2003 10:57 AM |
| Synthetic or not!!!! | obxfishn | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-17-2003 12:17 AM |
