stuck clutch pedal
Old 06-02-2015, 10:51 AM
grayberts's Avatar
stuck clutch pedal
I have an 86 4 runner. Pressed my clutch pedal the other day and it depressed with a little resistence. After it released it would not depress again. The clutch is engaged since i can shift from gear to gear and roll the vehicle when in gear without depressing the pedal. Any ideas out there of what might be the issue????? Thanks from a yotatech newbie.
Old 06-02-2015, 01:18 PM
wyoming9's Avatar
Red face
A little more back ground maybe??
Had things been working good up to this time??
Had your vehicle sat unused for a time like months ?/
For some reason weather something broke or has come apart or is stuck the clutch release bearing is holding the clutch plate against the clutch disc.
***Is the clutch bracket broke causing the Master Cylinder to bind ?? Since the pedal won`t move I would look into this first.****
Has the clutch slave cylinder vibrated loose and is now jammed unable to release
These are easy to see .
akamon808
3.4 Swaps
12-16-2015 08:45 PM
duncanmc
08-19-2015 03:13 PM
Motomonty
08-09-2015 05:53 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: stuck clutch pedal
