| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Steering wheel turned left after wreck
__________________
87 4Runner, 22re, 33MT's,4.88's and locked rear |
#2 (permalink) | |
If all the damage is on the right side then the right tire got pushed out and you have to compensate with the steering wheel to go straight. An alignment will fix you right up.
Look at the passenger side tie rod adjusting sleeve. Can you see any tie rod threads showing that look like they probably weren't before. Or your right side steering arm could be bent. You can check the gap between the rim of the wheel and the steering arm (part the outer tie rod goes through). The gap should be the same left and right. If you do go in for an alignment, let the mechanic know what happened so he will look closer for anything damaged. Is it going in to a body shop? A lot of those type of crashes automatically get an alignment ordered by the body shop.
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks 32x11.5-15 BFG AT's Quote:
#3 (permalink) |
I have not decided if i am going to take it to a body shop yet. I can find most of the parts locally for cheap, so i am going to do the work. I am afraid that if I make a claim and pay the deductible they will total it. Don't worry I reported it to insurance. I just choose not to get it fixed yet.
Last month I bought life time alignment, so I will go get one done.
__________________
#4 (permalink) |
I kinda did the same thing mudding last year, but the full force was directed on the left wheel (cruisin in a rutt and it decided to make a big 90* turn that I didn't see. Going from 10-15 miles per hour to a complete stop without any warning sure wakes you up haha). My steering wheel was off by more than a full turn though. Toyota quoted $1700 to fix it, but that's bearings, bushings, ball joints, etc; which I'm guessing were already going out. I just took the steering wheel off and repositioned it and drove it for many miles like that. I lost over a complete wheel crank to the right, but I can turn way sharper left now
__________________
'88 Toyota 4Runner (SR5?) 4x4, 3.0L V6, 5 speed, 31x10.5 tires, manual hubs and t-case, Rancho shocks, Rancho steering stabilizer, Borla muffler, K&N air filter, Procomp front bumper, 2 cheapo flood/driving lights from Advanced Last edited by nosfanatic2006; 10-22-2009 at 06:28 AM. |
#5 (permalink) | ||
Quote:
__________________
| Tags |
| alignment, bellingham, completed, damages, left, rubicon, side, slightly, steering, straight, stright, tires, turned, wheel, wreck |
