Last edit by: IB Advertising
- Toyota 4Runner, Tacoma, and Tundra Paint Modifications<br>Overview of popular modifications to help you customize your Toyota.
Show us your best cheap mods!
#1146
reinforced gas tank skid plate
I reinforced and stiffened up my gas tank skid plate with some #3 rebar ...
then I made some some L brackets and mounted it to the frame ... (truck is heavily modified so skid plate no longer lined up with old mounting hardware)
...about $14 in rebar , $6 in primer, and I feel much more confident that my skid plate can take a good hit.
#1149
Jolene, you might look into a 90 degree connector so the aux stays connected, but that's a fantastic setup.
My ultra-cheap mod is a light reminder (I kept draining my battery ). Get any cheap, loud 12v noise maker and wire it between the TAIL and IGN fuses (if your noise maker is dioded, wiring it one way will remind you to turn them on, the other, to turn them off; if it's not dioded, it will remind you to do both).
- 3pk fuse taps - US$9
- 2pk beeper/flasher - US$8
- 25' black/red wire - US$5
- 2 fuse taps - US$6
- 1 beeper/flasher - US$4
- 2' black/red wire - US$0.40
#1150
#1151
Some people may not like carpet in their rig but this is a flip for me so I decided to do Home Depot carpet like I have in the past. 18 bucks and some 3M spray adhesive, little bit of measuring and some patience and it will look pretty damn good.
Had to cut out a section to go around the center bottom dash support, should have left a flap of carpet to go completely around it. Planning and measuring and really thinking about how you want to lay the carpet down makes life a lot easier
All in all I'm happy with the result and if you guys need any more info on the carpet I have the part number and exact prices and can show you the 3M spray. Let me know what y'all think.
#1153
#1154
Lower seat/remove slider mechanism
I barely fit into my recently acquired '83 standard cab so I decided to remove the bench slider in an attempt to move the seat down and back.
First I pulled the seat (four bolts). The slider is held in place by four bolts (12mm I believe). I grabbed some cheap steel from the hardware store to make new brackets with. Here is the back bracket utilizing the stock bolt that held the slider on:
Here is how I did the front:
Pound the front one down and attach with the stock bolt/nut to the floor pan:
I just zipped a sheet metal screw in for the back one:
Repeat on the other side.
The seat sits awesome now and I have tons of room. I gained a ton of headroom, I have a nice reach to the wheel and it feels way more solid than before.
#1156
Not really. The seatbelts are still bolted to the floorpan. Not to mention the seat is in stronger than the old rattly slider mechanism was holding it so if anything this is an improvement.
#1159
Staff
For a broken antenna here is how I go about fixing mine.
How I fix the broken antenna. I use a 14mm bolt or similar size and thread it into the broken pvc tube.
Then I cut the head off.
Then thread the other piece back into the threaded piece. I have never had one to fail after I have done this repair. I see numerous trucks with antennas tilted back and it is from the pvc being broke.
