Shock length for 2inch lift
Recently bought a 94 pickup with a 2inch lift. Shocks they had on it are pretty worn out so looking to upgrade. Thinking kyb monomax since i can get a set on rockauto.com for $220 shipped. anyone have recommendations on length for these? I see a lot of shocks rated for stock suspension but it's hit or miss finding something for a truck with a lift. Any suggestions and advice is greatly appreciated. I attached a picture of the truck as well Thanks
You measure distance between to shock mount with bottom shock mount at both full compression and full droop. Figure out mount shock mount style. Use whatever brand shock you want to run's catalog to select part number and order from favorite vendor.
If you know old whocks are correct size. Use whatever brand shock you want to run's catalog to select part number and order from favorite vendor.
or pick a brand of shocks that caters to matching vehicle to lift height and part number. Order those shocks from favorite vendor.
4Nmissile
11-14-2016 08:54 AM
