shaking problem when on the highway for a few minutes, then goes away
Old 04-14-2012, 01:57 PM
mytoyota hates me's Avatar
my problem is that when i get on the highway, i get a shaking problem, then when i hit the brakes its really bad. it goes away till i go back to a lower speed, then comes back and goes away again. i have aftermarket wheels, and the alignment is good, and have replaced all of the brake components, along with a reframe. help me please...
Old 04-14-2012, 03:41 PM
Team420's Avatar
Generally speaking... if the vibration changes with speed ie: vibes at 40, but goes away at 60, then returns at 70.... its usually related to tire balance, or a warped/bent rim, or bad belts in tires.... If it vibes when hitting brakes always, then rotors are suspect, or possibly a bent rim.
Hit any nasty potholes lately?
Old 04-14-2012, 04:01 PM
stanz's Avatar
How well do the wheel centers fit your front hubs and rear drums? I had an issue with my Jetta when the aftermarket wheel centers were too large. It caused a lot of vibration at highway speeds and killed my wheel bearings. I had to get hubcentric rings to fill in the difference. Once I did, it drove great.
Old 04-14-2012, 05:56 PM
cr@ves4wheelin's Avatar
When you say brake components, did that include rotors? If not, the cause might be warped rotors.
Also, I had my truck start shaking on the highway when my rear wheel bearing was bad. Just something to think about.
Old 04-14-2012, 08:10 PM
thank you
thank you all for the info, it ended up being the left caliper, which i replaced 2 years ago, and by all components i did mean rotors, pads.. front and rear, new right side caliper, as for the wheels, they suck but look good.
Liadrin
04-25-2022 02:54 PM
the1998sr5
15
07-14-2020 08:35 PM
Liadrin
09-01-2015 06:44 AM
rushw
07-18-2015 01:46 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: shaking problem when on the highway for a few minutes, then goes away
