YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-30-2006, 03:46 PM   #1 (permalink)
AlexJet's Avatar
Rubbing with 275/70-R17 tires
I've put Goodyear MT/Rs this afternoon on my truck. Finally. They've been in my garage for a month; I was waiting good weather to put them on.
After I put them and made a test drive around the block (~5miles), I did mentioned rubbing. I knew it's going to rub a little, but after what I saw, I start worrying.
They rub not only mud flaps, but ALL triangles on the front bumper. I was expected a little rubbing on triangles. So I checked how much should I trimmed. I'm not sure if after removing triangles I would get rid of rubbing. Maybe in city driving yes, but what about off-roading when I'm using all wheel travel up and down. I'm afraid that 275/70-17 might rub the plastic fender when the shock will be fully compressed.
May be I'm wrong, that's why I'm asking for an opinion from members of this forum. I talked to the guy I got my tires from and he said he will check with GoodYear, if I can exchange 275/70-17 for 265/70-17.
P.S. I tried to cut right mud flap, but it still rubbing.
__________________
2005 4Runner V6 Limited
with tons of mods...
AlexJet is offline
Sponsored Links
To remove this ad, register today!
Old 03-30-2006, 03:58 PM   #2 (permalink)
4RUNN!N's Avatar
Since they are an MT tire, they would probably rub more than the same size AT or HT tire.
__________________
1997 4Runner Limited 4WD
4" Deckplate
True Flow Air Filter
Gray Wire Mod
LT265/75R16 Hankook Dynamic RF04 Tires
Lift coming soon
4RUNN!N is offline
Old 03-30-2006, 04:06 PM   #3 (permalink)
AlexJet's Avatar
I have 3" Cornfed Lift on my truck, but this is not helping as I was thinking.
__________________
AlexJet is offline
Old 03-31-2006, 05:14 AM   #4 (permalink)
Lefty's Avatar
That rubbing isn't any worse than the rubbing I got with my 265/70R17 BFG A/T's. I wouldn't worry about it too much.
First, just remove those mud flaps instead of trying to trim them. They eat up close to an inch of your wheel well space. There are, I believe, 4 bolts each that hold them to the body. Then, crank out the hacksaw and cut those wierd fender extensions/whatever-they-are-called in the front of each wheel well completely off. Those things do a better job of catching mud/dirt than directing wind around the front tires (what they were designed to do). That should do it !
By the way, you'll probably encounter much the same rubbing, just less of it, if you go down in size to 265.
Good luck !
Steve
__________________
'03 V8 4Runner 4x4 SR5
*OME Lift*MV-50 OBA*Yak rack*Lightforce 170s*
Lefty is offline
Old 04-01-2006, 11:41 AM   #5 (permalink)
AlexJet's Avatar
What do you think guys if I'll put 1" body lift from 4Crawler? Is it going to help?
__________________
AlexJet is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Anyone running Goodyear Wrangler Silent Armor 275/70/17 tires? gkatmar 03+ 4Runner/GX470, & 05+ Tacomas 4 02-01-2007 06:07 PM
Need one used 275/70/16 tire aowRS Items Wanted 3 01-12-2007 08:30 PM
265/70 vs. 275/70 Bridgestone Revos? jodynich 95.5-2004 Tacomas & 96-2002 4Runners 3 03-24-2006 04:01 AM
Cornfed 3" with 305/70/R17 on a '98 Delaware 95.5-2004 Tacomas & 96-2002 4Runners 32 03-03-2006 06:33 AM
Help!!! 275/55-20 tires are rubbing 4runner 95.5-2004 Tacomas & 96-2002 4Runners 2 05-15-2003 06:21 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
