| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Rear axle bearing.. To replace or not?
#2 (permalink) | |
could be worth doing, depends on the mileage, which is...?
(still) sealed bearings should be fine for many many miles
__________________
sarcasm noted...and appreciated im with the banned Quote:
#4 (permalink) |
If the inner seal leaked and let gear oil get to the wheel bearing and oil was leaking through the bearing seals, then yes, the bearing grease has likely been washed out (BTDT). If no oil has gotten to the bearing, then it is up to you on replacement. Should run 200K pretty easily on the wheel bearings. If it feels tight, then keep it in there. You are trading off the cost of the bearing vs. a future cost of the bearing plus the labor to change it (which you are already paying for with the seal R&R).
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#5 (permalink) |
Lets see....the arguement is that the diff oil has washed the grease out of a SEALED bearing? This is a new use of the word 'sealed' which I am previously unfamiliar.
Replace the bearing when its worn. Mine lasted 160K miles, and two or three axle seals.
__________________
03 Dodge Ram 2500 CTD...its amazing Ex: 1999 4Runner JT3HN86R1X0199261...Now somebody elses Karl Malone Toyota 'Certified' POS Legendary Toyota quality is exactly that: A thing of legend. Defective fuel gauge - 'Certified' Defective brake rotors - 'Certified' Defective axle seals - 'Certified' Defective heater diverter - 'Certified' etc. etc. etc. |
#6 (permalink) | |
Quote:
![]() just bite the bullet and replace it. |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) |
i will second rogers posting, it happened exactly that way on my 93. when we got the bearing off the axle, there was NO grease what so ever left in the bearing, the seals were gone as well. ive done both of mine, at different times. the drivers side was a piece of cake but the pass side had to be cut off. no amount of pounding on 1" plywood would budge the bearing. my hands were aching for several days afterwards.
lee
__________________
93 sr5 v6 auto, 4x4 Photos http://s866.photobucket.com/albums/a...albumview=grid there are quite some attractive ladies on here with Toys. (compliments of ironmike) ifsc 3(.0) http://tlca.org www.of4wd.com www.sontt.com |
#9 (permalink) |
The outer seal is nothing but a dust seal, not intended to keep in fluid. The bearing does not make a good seal to the axle housing, nor to the hub. Diff fluid leaks from the inner seal, goes between the bearing and the axle housing and hub and on out.
__________________
#11 (permalink) |
__________________
#12 (permalink) |
Once the inner seal (axle housing and axle shaft) leaks, oil start going through the sealed bearing on the axle shaft washing out the thick grease. If you replace the axle seal, the bearing will no longer have sufficent lubrication and will prematurely fail. Now if there isn't too much play in the bearing, you can simply re-pack them. I used a small nail head to pry off the seal on the bearing, then use a thick moly bearing grease, pack in as much as possible and re-install the seal.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 90 4runner axle bearing replaced..replace inner seal? | 4rockclimber | 86-95 Trucks & 4Runners | 2 | 01-09-2007 01:39 PM |
| Rear Axle Bearing Install Check | EvergreenFJ60 | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 12-06-2006 08:06 PM |
| replace rear diff or rear axle... in a bind | old 86 | 86-95 Trucks & 4Runners | 6 | 11-11-2006 10:20 AM |
| Difficulty of Rear End Axle Seals and Bearing Replacement? | bsanders30096 | 86-95 Trucks & 4Runners | 13 | 05-11-2006 09:09 AM |
| Replace rear axle u-joint | Ranski | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 04-23-2004 12:38 PM |
