Quick 2nd gen help... grommets in firewall ? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-12-2005, 06:43 AM   #1 (permalink)
nrgetic99's Avatar
I just started adding an alarm to my 2nd gen as I am too lazy to open my doors with a key
Seriously, I am only going to be using the remote locking features for now and also a remote starter as I will be parking it at the ski resort most weekends and a warm truck is much easier to clean ice and snow from than a cold one when you want to drive home.
I am in pretty good shape but want to run a couple of wires through the firewall for my hood pin switch and tach wire (have to use under hood diagnostic port for a negative tach feed ). My 3rd gen had a really nice grommet on the DS firewall but it looks like I may be out of luck on my 2nd gen.
There is a big grommet high on the PS firewall that takes the main loom from the battery/under hood fusebox. I am eyeing that right now.
Anyone done this recently ? Where is the easy spot to pass through the firewall.
Thanks
David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow
93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ...
03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-(
99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten
96 SR5 Dune... 1.5kw stereo
nrgetic99 is offline
Old 12-12-2005, 03:33 PM   #2 (permalink)
DH6twinotter's Avatar
I used the grommet on the driver's side, right where the hood latch release goes through. I ran my CB wires/cable and a few other things that were really lame (don't ask ) through that grommet. If you have to go on the passenger side, than I would probably use the grommet you mentioned.
Just my $.02
Daniel
__________________
1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto.
15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick
Planned stuff: Pre-runner light bar with Hella 500s, small lift
Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow.
DH6twinotter is offline
Old 12-12-2005, 03:38 PM   #3 (permalink)
Epic Ed's Avatar
I drilled my own hole and I'm still looking for a suitable grommet to fit the area. It adds to the noise level a little, but I figured it would be easy enough to fix. I just haven't found the right part yet (or don't know where to look).
Ed
__________________
'95 4Runner|32x11.5 BFG TA KOs|Hi-flow Cat|Dynomax muffler; 2.25" exhaust| Downey Headers|4.88 gears |Detroit EZ locker |Detroit TruTrack|BJ spacers|Downey HD coils|2" rear spring spacers|Rancho RS9000X/RS5000s|WARN hubs|TJM T15
Epic Ed is offline
Old 12-12-2005, 03:42 PM   #4 (permalink)
Godzilla's Avatar
yes, there is a grommet of the DS. it can be tough to see , but it will go right into the area above your pedal linkages making it perfect location to run switches through.. its only abount an inch in diameter
Godzilla is offline
Old 12-12-2005, 03:48 PM   #5 (permalink)
Just make sure you don't leave part of the grommet hanging out or something like that. It needs to be seated properly in the hole. Mine was buggered up and I had water coming in. If you do drill a hole, try to waterproof it somehow.
__________________
Old 12-12-2005, 04:26 PM   #6 (permalink)
tc
tc's Avatar
I just added some lights nrgetic, and understand what you're talking about. The PS grommet is bigger, and very nicely placed for access to the battery, unfortunately, you will basically have to remove the entire dash to get the wire down where you can do something with it! The DS grommet is smaller, but you can reach right up there and pull the wires through.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 12-13-2005, 05:39 AM   #7 (permalink)
nrgetic99's Avatar
Quote:
I used the PS grommet and just ran a fish tape down through the grommet and pulled the wires back up behind the heater to the grommet with the tape.
Worked great.
Results here http://www.yotatech.com/showthread.php?t=73897
David
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Drilling new grommets through firewall Erich_870 Vehicle Audio & Home Entertainment 7 02-19-2007 07:29 PM
Tubing The Firewall On A 2nd Gen 914runner The Fab Shop 3 02-15-2005 07:19 AM
Quick 2nd Gen Question... jimrockford 95.5-2004 Tacomas & 96-2002 4Runners 16 01-01-2004 08:14 PM
Which silicone for firewall grommets Corey 95.5-2004 Tacomas & 96-2002 4Runners 7 04-04-2003 12:51 PM
2009 InternetBrands, Inc.
