oil pressure at idle - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-30-2009, 02:33 PM   #1 (permalink)
After warming my truck up this morning, I noticed the oil pressure seemed quite low at idle. I've got the factory oil pressure gauge infront of the shifter on my '83. When the engine was warming up, before the thermostat opened it was in the middle of the gauge, the choke was off. After the temp gauge reached halfway, I looked at the oil pressure gauge and found it seemed quite low, but havent owned the truck long enough to know how low is normal. I snapped a picture on my phone, so if anyone can clarify, is this too low? the gauge seems to work fine, like the pressure raises right up at higher rpms, it just seems quite low at idle.
85triz is offline
Old 10-30-2009, 06:03 PM   #2 (permalink)
yoterr's Avatar
well if you get urself a mechanical guage idle psi is supposed to be around 4 psi, and jump to 50-60? psi at 3K so if your truck was cold it would be idled up making the oil pressure higher than it is at idle
__________________
new to me 86' toy on 35" procomp mud terrains, with a 4" lift and 3" body and palm fron camo for now...
04' Dodge 2500 4x4 QC hemi leveled, home made CAI and flowmaster exhaust
yoterr is offline
Old 10-30-2009, 08:45 PM   #3 (permalink)
ajoebob's Avatar
its just a toyota thing. mine dose the same thing so i put a new oil pump on it and its still the same.
__________________
'82 toyota pickup 5" lift, weber 36deg carb, 32x11.5 sx super swompers,rear aussie locker,5.29 gears, cb, and 261*c cam
ajoebob is offline
Old 10-30-2009, 09:20 PM   #4 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Yea, its gonna be low at idle. Like yoterr said, on the cold start the engine was at high idle so the pressure was higher.
Adam F is offline
Old 10-30-2009, 10:19 PM   #5 (permalink)
Built2Grind's Avatar
mine had a bad sending unit, it would start out fine and slowly go wayyyyyy too low. i got really worried about it and got a mechanical gauge. everything was fine mechanically. 1 new sending unit and TA DA problem solved
__________________
POS 3vz-e, 4x4, extra cab, SR5, 31's, glasspack, swaybarless and never going back!
Built2Grind is offline
Old 10-31-2009, 05:13 PM   #6 (permalink)
Thanks guys, thats the answer I was hoping for
85triz is offline
Old 11-02-2009, 06:20 AM   #7 (permalink)
83
83's Avatar
Here's mine, but it's a rebuilt engine..
__________________
Zach
'83 Shortbed 4x4
L52HD
Rebuilt & Mostly Stock
83 is offline
Old 11-02-2009, 11:19 AM   #8 (permalink)
is that fully warmed up, after the thermostat pops? thats about where mine was at an idle before it fully warmed up. i had kicked the high idle down and the choke was off, the engine just wasnt completely warm yet. then after it was fully warmed up it slid off to what you see in my pic.
85triz is offline
Old 11-02-2009, 11:35 AM   #9 (permalink)
toyota4x4907's Avatar
Send a message via MSN to toyota4x4907
Quote:
Hm. Mayhaps thats whats wrong with my 22re pressure....or..it could be the main bearings since I get a slight knock on cold start sometimes ....but I have pretty much the same symptoms you describe here. It starts out fine, then after driving 15+ minutes constantly, it goes down to ALMOST the low level. and it usually stays there, even if I hit 4K rpm. it usually moves higher by about a needle width when I let off the gas ...then goes down again.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler
'88 4runner|22re|5spd|206K miles|Sold
'93 single cab|22re|5spd|150K miles|Sold|
Pro IFS
toyota4x4907 is offline
Old 11-02-2009, 02:15 PM   #10 (permalink)
83
83's Avatar
Don't remember...I'll look later today if I remember. Seems like you're ok, though.
__________________
Zach
'83 Shortbed 4x4
L52HD
83 is offline
Old 11-03-2009, 02:36 PM   #11 (permalink)
83
83's Avatar
I feel like when my truck is really warmed up (like after some time on the highway), at idle, it goes a bit lower, but just now, after getting heat in my cab, and sitting at idle, the needle was right at the first line. So just a bit lower than in my photo, but not much. Like I said, though, rebuilt engine.
__________________
Zach
'83 Shortbed 4x4
L52HD
83 is offline
Tags
idle, low, oil, pressure, toyota, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
