oil additive to swell seals - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 12-12-2008, 12:40 PM   #1
I've never been able to find any additives on the shelf that swell the valve seals. What am I supposed to look for? Oils made specially for older, high-mileage engines? Or is there a specific additive you guys recommend?
DupermanDave is offline   Reply With Quote
Old 12-24-2008, 05:00 PM   #2
Ron Helmuth's Avatar
that is a temporary fix at best.
I think you look for that oil additive stuff that is guaranteed to pass your emission test-then the next oil change you are right back where you started.....
Ron Helmuth is offline   Reply With Quote
Old 12-25-2008, 10:44 AM   #3
Quote:
I hear this so many times on this forum. What people don't realize is that it gets -20 degrees here in Colorado and changing seals in this cold is not fun. So for now it has to be a temporary fix until the weather permits the work to be carried out.
Old 12-25-2008, 10:45 AM   #4
airmen65's Avatar
ahhh if only we all could have heated shops. . lol.
airmen65 is offline   Reply With Quote
Old 12-26-2008, 10:37 AM   #5
understood DupermanDave
good point
Old 12-26-2008, 10:51 AM   #6
EvaMonky's Avatar
Quote:
Oil leak fix additives.
That stuff you put in your gas tank. There is nothing that is going to help you pass an emissions test by putting it in your oil....
They test your exaust for unburned Hydrocarbons. Not your Oil for fumes.
Because so many times people want the easy way out. People are naturally lazy! Some actually belive it's a permament fix.
Changing out seals in that weather may not be fun. That's why you pay someone else to do it!
There's really no guarentee that any of that crap will work anyways... You could just be throwing your money down a burning pit. .
EvaMonky is offline   Reply With Quote
Old 12-26-2008, 01:23 PM   #7
Wal-mart has an oil additive that promises to stop smoking and burning oil and it also states it will help pass emissions. I'll try and snag a picture when I go to that wal-mart.
Even a garage with a space heater isn't good enough for winter truck repair. Winter sucks.
The Rebuild of Lucy. 1982 4X2 Standard Pickup jasonty Pre 84 Trucks (Build-Up Section) 38 10-05-2016 03:17 PM
20R Break in- Really High Oil Pressure calderp Engine Swaps 2 08-16-2016 06:15 PM
HiGH oil pressure breaking in 20R calderp Pre 84 Trucks 8 07-27-2015 10:58 AM
Bent frame reliablity yourrealdad 95.5-2004 Tacomas & 96-2002 4Runners 2 07-21-2015 12:13 PM
Need help Oil Leak jakebarrett 86-95 Trucks & 4Runners 3 07-10-2015 08:15 PM
Tags
additive, additives, due, emission, fix, high, leaky, mileage, oil, pass, put, seal, seals, swell, temporary, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
