Sign in using an external account
| General Vehicle Related Topics (Non Year Related) If topic doesn't apply to Toyotas whatsoever, it should be in Off Topic |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
main bearings...to replace? or not
#2 (permalink) |
Personal
Sales Rating: (0)
Actually, replacing the top half of the main bearings isn't difficult at all. Find a nail whose head is slightly thinner than the thickness of the bearings, and cut it short enough that it can fit down into the oil passage on the crankshaft, with just the head sticking out. Now rotate the crankshaft with a socket so that the nail head pushes on the end of the main bearing which DOESN'T have the retaining notch, so the retaining notch comes out first. Installation is the reverse of above, rotate the crankshaft the other way so that the nail pushes the retaining notch so that the notch is the last thing in.
I did this with my 89 22R, in my driveway, also replaced rod bearings while it was apart. Piece of cake! |
#3 (permalink) |
Personal
Sales Rating: (0)
Since you are at (or almost at) the maximum wear anyway, I would vote replace them.
I would also suspect that the knock is from a rod bearing rather than a main bearing. When I ripped apart my 1993 22RE, the mains all looked fine. It was the (number 2 I think) rod bearing that was toast. It wasn't worn, it was completely gone! As in not there! The guy I got it from kept driving it after he new it spun a bearing. Then he gave the truck to me when he thought he couldn't drive it any more. I then proceeded to drive it the mile or so to my house with the loudest knock I've ever heard come from a motor. I ended up pulling and rebuilding it. I used the crank, rods and caps from an older 22R and bought a lower end rebuild kit from engnbldr for around $350. Everything has been kosher since. Knock on wood. It's been about 7500 miles so far. Good luck. |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
well, the rod bearings are in great shape. I haven't taken the caps off, but there's zero play in them. I pried and shook, and they're very solid. but without the thrust washers the crank had shifted forward quite a bit. so I'm thinking that was the cause of the horrible sounds it was making.
well, I guess I'll order a set of mains... |
#5 (permalink) |
Personal
Sales Rating: (0)
If you haven't removed the rod caps to LOOK at the bearings, then you can't really say whether they are in good shape or not. Simply trying to move the rod and "feel" for play is not sufficient, as the amount of wear required to knock under running conditions, spinning at 2000-4000 rpm, cannot be felt by the human hand when the engine is cold.
If there is the slightest doubt, replace them anyway, while the pan is off. Don't be an example of "there wasn't time to do the job right the first time, but there is plenty of time to do it over". |
#6 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
but yes...you're right, I should, and probably will pull the caps off (at least the 2 in the back were the knock was coming from) to ensure that they are ok. but I suspect they are, judging from the condition of the main. I should also mention, that it was only the #3 bearing that read .003. the other 4 were .002 or smaller (the plastigage I was using only went down to .002). |
#7 (permalink) |
Personal
Sales Rating: (0)
I'm curious how this turned out for you. what did you end up doing and if the crank moved 1/4 inch was there concern that the pins in the pistons might have had a problem? Getting ready to replace both rod and main bearings with the engine in my truck in the driveway.
__________________
84 Runner stretched and pounded but still crawlin 98 Runner SR5, 3.4SC'd, 5 speed, kings f/r, ARB Locked F/R on 35's |
#8 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
Hey, I was out of town for Winter break. and then it's been below zero almost every day since....so not much has happened. I tested the other 4 main bearings, and all 4 rod bearings. finding that all 4 mains were right about at .002, so it could go either way. so I opted to replace them (I have them...but haven't replaced them). and that the rod bearings were safely inside the standard clearances. so I'm going to keep those. I've also got the new thrust washers. I am mildly concerned about the wrist pins. but I just keep telling myself that with the length of the rod, and less than 1/4" of play at the base, that the amount of twisting force would be pretty minimal....and that the engine has very few miles on it since they problem. unfortunately, my options are pretty limited. I'm not pulling the head unless I absolutely have to....so I'm going to replace the main bearings and thrust washers, reassemble...and see where that leaves me. Last edited by Numbchux; 02-08-2007 at 03:46 PM. |
#9 (permalink) |
Personal
Sales Rating: (0)
thanks for the update. I did both main and rod bearings yesterday. came out great and boy did they need to be done. over 200000 miles on the motor and was down to the brass in the bearings. Now runs smoth and no knocks.
__________________
#10 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
I did check the tolerance on a couple of the main bearings just to be sure that it was the bearings that were worn, and not the crank, and it was well within spec. maybe the wrist pins are shot, or maybe the crank is. I don't know.... |
#11 (permalink) |
Personal
Sales Rating: (0)
I would vote for wrist pins because that is a forged crank from toyota. Sorry to hear about your motor.:pat: :pat: :pat:
__________________
#12 (permalink) | |
Personal
Sales Rating: (0)
Quote:
I've got a full bearing set sitting here, and it just dawned on me that to replace the mains I'd have to pull the tranny. That's a pain I'd rather avoid if possible(I know, not tough, just time consuming).
__________________
86 Turbo Pickup EB Street RV head EB 268 Cam V6 Brakes + MC A340F auto ---> W56 5-spd swap ...I want a bigger turbo... |
#13 (permalink) |
Personal
Sales Rating: (0)
Bill
don't drop your trans. just like Ron said, do your rod bearings first, then loosen all of your main caps and get them hanging on the bolts. one by one replace the bearings, I didn't event have to rotate the crank I just used a small flathead screwdriver and sliped out the top bearing then sliped the new one back in. put the cap back on with out snugging it up and move to the next one. Once all the bearings are replaced torque the main caps starting from the center and then working out from there. easy as pie. you wont get to do the rear seal but if it is not leaking your golden. if it is leaking you have to pull the trans. Good luck.
__________________
#14 (permalink) |
Personal
Sales Rating: (0)
Ok good, thanks for the tip!
I'm working on this by myself (all my auto-savy friends have "jobs", and my school friends don't know a torque wrench from a c-clamp), and I wasn't looking forward to pulling the crank, let along pulling the trans alone.
__________________
#15 (permalink) | |
Personal
Sales Rating: (0)
[OP]
Quote:
I actually pulled all 5 main bearing caps, and laid them in order, in a box, labeling which end was the front of the motor. then replaced the top halves of all 5 bearings, and then bolted the caps up. and like rock dawg said....get them all hand tight before putting final torque on them. I attached the FSM diagram about the order in which to torque down the mains. |
#16 (permalink) |
Personal
Sales Rating: (0)
way to go.
__________________
#17 (permalink) |
Personal
Sales Rating: (0)
I am considering replacing the rod and main bearings in my 92 22re. The timing cover has the now infamous chain hole in it and water got into the oil. Can anyone tell me how much and where to buy the rod and main bearings? My toyota stealer wants a little over $300 +tax. Thanks
Oh, the truck has 176K, 5 speed. Have to pull the oil pan anyway to fish out the timing guides. |
| Tags |
| bearing, bearings, caps, cost, crankshaft, heads, main, motor, order, put, removing, repair, replace, replacing, rplace, subaru, truck, wrong |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wheel bearings? | Mister Willie | 86-95 Trucks & 4Runners | 21 | 10-29-2006 11:32 AM |
| Crank Bearings | Firefightertaco | 86-95 Trucks & 4Runners | 4 | 10-24-2006 08:49 AM |
| Engine Main Bearings and Rod Bearings | 87TurboYota | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-30-2005 11:17 AM |
| Anybody replace their rear main seal themselves on 2nd Gen? | EOD30 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 09-21-2004 05:18 AM |
| Wheel bearings | Mikey | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 05-13-2003 09:02 AM |
