YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 03-05-2008, 08:43 AM   #21 (permalink)
Personal Sales Rating: (0)
Threadstarter [OP]
Brenjen's Avatar
Quote:
Originally Posted by GSGALLANT View Post
I haven't gotten wheel bearings from them, but I've purchased different bearings from the differential and they were KOYO.
As far as how to find them, for front wheel bearings, check the following path in the drill down of the mechanical catalog "Front Suspension - Suspension Components - Front Wheel Bearing". For rear wheel bearings, check the following path in the drill down of the mechanical catalog "Universals & Rear Axle - Rear Axle - Axle Bearings".
If there's something that you can't find on their website, you can always call or email them and they are more than happy to help you out.
Good luck.
Yeah I found the axle bearings, engine bearings etc just fine before, it's only the front wheel bearings I can't find. I might call them if DTB can't get the bearings for one reason or another.
Quote:
Originally Posted by dirtoyboy View Post
..chances are your "japanese" toyota is not made from "japanese" steel......most of their raw steel on the island was used up during WWI....they still process their steel IN japan but get the raw materials from other countries...
at least thats what I was TOLD...not sure if its completely true
Yup, & that main "other country" is the U.S. scrap industry from what I've heard/read; except from 1939ish to around 1945ish for obvious reasons.
__________________
'95 4Runner 3.0 Automatic;Ball joint spacers,OME shocks & steering stabilizer,Performance Products 1" progressive,ARB locked front & rear,Sonoran Steel IFS truss,idler arm truss with bronze bushings & the infamous quick CV change mod (ground off splines)
Brenjen is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 03-05-2008, 02:34 PM   #22 (permalink)
GSGALLANT's Avatar
Quote:
OK... well if you re-read my post above and go check the website out, I showed you exactly where to go to find the front wheel bearings. Both the inner and outer bearings are there.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2007 FJ Cruiser - stock
GSGALLANT is offline
Old 03-05-2008, 03:45 PM   #23 (permalink)
Threadstarter [OP]
Brenjen's Avatar
I did go back & re-read the post & you are absolutely correct, I missed it (several times) It was the "front" part that was throwing me, I was going down to "wheel" & seeing the seal & "bearing" at the top was for Land Cruisers.
After I opened two pages & looked word for word in your post I found them. You're a benefit & a gentleman! Thanks; I owe you one!
__________________
Brenjen is offline
Old 03-06-2008, 05:47 AM   #24 (permalink)
Threadstarter [OP]
Brenjen's Avatar
(even though all the listings are for 2WD 4Runners....do the 2WD & 4WD 4Runners use the same bearings???) If they do, that's a new one on me.
__________________
Brenjen is offline
Old 03-06-2008, 06:36 AM   #25 (permalink)
GSGALLANT's Avatar
Good point, and good question. I can't check here from work, but I can check my parts list when I get home if I don't forget... unless somebody else can provide the answer here before then.
__________________
Old 03-06-2008, 08:13 AM   #26 (permalink)
dirtoyboy's Avatar
My Toyota dealer said they have the bearings but they cannot guarantee what you get....its whatever they have in stock.... Koyo, NTN or Timken...this probably doesnt help much lol
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 03-06-2008, 08:30 AM   #27 (permalink)
Threadstarter [OP]
Brenjen's Avatar
I'm thinking of laying out for these: KOYO BEARINGS Just not sure I trust 'em; sounds too good to be true at that price for all four.
Edit: Well I ordered a set. Can't beat that price for all four bearings! I'll post up when they arrive to let anyone else interested in buying a set of these if the seller is straight up or not.
__________________
Brenjen is offline
Old 03-06-2008, 03:17 PM   #28 (permalink)
GSGALLANT's Avatar
Wow... real good deal if you get what they say you'll get. Anyways, I did check and both 4WD and 2WD 93-95 4Runners (and many more, I'm sure) take the same bearings:
Inner (LH & RH):90080-36064
Outer (LH & RH): 90080-36067
The Toyota parts catalog says they use Timken for front bearings (I can't remember what's in my '93 for front bearings, but I know the rears were KOYO). I'm sure it's like dirtoyboy said... whatever the particular dealership is stocking at the time. I'm sure the KOYO's you are getting will be fine as long as they fit.
__________________
Old 03-06-2008, 03:57 PM   #29 (permalink)
Threadstarter [OP]
Brenjen's Avatar
Thanks for the help; the numbers may help someone in the future in a search!
__________________
Brenjen is offline
Old 03-12-2008, 11:28 AM   #30 (permalink)
Threadstarter [OP]
Brenjen's Avatar
Well, the e-Bay Koyo bearings came in today & they are indeed Koyo brand. $75.99 was a hard price to beat for all four bearings & races & that was pretty fast shipping for a west coast e-Bayer; now I just hope they are the correct ones. Part number changes & revisions always leave me scratching my head & I obviously know nothing about the part numbers I needed for this Toyota; I hope this isn't one of those head scratching times. We'll see in a couple days Lord willing & the river don't rise.
__________________
Brenjen is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
33, 9008036064, 9008036067, bearings, china, gri, ifs, koyo, made, parts, raw, sonoran, steel, toyota, truck, truss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
bearings tampabayota General Vehicle Related Topics (Non Year Related) 3 11-01-2007 01:18 PM
KOYO Aluminum Radiator QSVeilside General Vehicle Related Topics (Non Year Related) 3 01-23-2007 02:49 AM
Engine Main Bearings and Rod Bearings 87TurboYota 95.5-2004 Tacomas & 96-2002 4Runners 3 03-30-2005 11:17 AM
Wheel bearings ElwayLite 95.5-2004 Tacomas & 96-2002 4Runners 2 06-09-2004 04:16 AM
Rod Bearings merrill94 Maintenance & Repair Archives 4 11-06-2003 06:40 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
