Koyo bearings
I haven't gotten wheel bearings from them, but I've purchased different bearings from the differential and they were KOYO.
As far as how to find them, for front wheel bearings, check the following path in the drill down of the mechanical catalog "Front Suspension - Suspension Components - Front Wheel Bearing". For rear wheel bearings, check the following path in the drill down of the mechanical catalog "Universals & Rear Axle - Rear Axle - Axle Bearings".
If there's something that you can't find on their website, you can always call or email them and they are more than happy to help you out.
Good luck.
Good luck.
..chances are your "japanese" toyota is not made from "japanese" steel......most of their raw steel on the island was used up during WWI....they still process their steel IN japan but get the raw materials from other countries...
at least thats what I was TOLD...not sure if its completely true
OK... well if you re-read my post above and go check the website out, I showed you exactly where to go to find the front wheel bearings. Both the inner and outer bearings are there.
After I opened two pages & looked word for word in your post I found them. You're a benefit & a gentleman! Thanks; I owe you one!
(even though all the listings are for 2WD 4Runners....do the 2WD & 4WD 4Runners use the same bearings???) If they do, that's a new one on me.
#25
Good point, and good question. I can't check here from work, but I can check my parts list when I get home if I don't forget... unless somebody else can provide the answer here before then.
#26
My Toyota dealer said they have the bearings but they cannot guarantee what you get....its whatever they have in stock.... Koyo, NTN or Timken...this probably doesnt help much lol
#27
I'm thinking of laying out for these: KOYO BEARINGS Just not sure I trust 'em; sounds too good to be true at that price for all four.
Edit: Well I ordered a set. Can't beat that price for all four bearings! I'll post up when they arrive to let anyone else interested in buying a set of these if the seller is straight up or not.
#28
Wow... real good deal if you get what they say you'll get. Anyways, I did check and both 4WD and 2WD 93-95 4Runners (and many more, I'm sure) take the same bearings:
Inner (LH & RH):90080-36064
Outer (LH & RH): 90080-36067
The Toyota parts catalog says they use Timken for front bearings (I can't remember what's in my '93 for front bearings, but I know the rears were KOYO). I'm sure it's like dirtoyboy said... whatever the particular dealership is stocking at the time. I'm sure the KOYO's you are getting will be fine as long as they fit.
#30
Well, the e-Bay Koyo bearings came in today & they are indeed Koyo brand. $75.99 was a hard price to beat for all four bearings & races & that was pretty fast shipping for a west coast e-Bayer; now I just hope they are the correct ones. Part number changes & revisions always leave me scratching my head & I obviously know nothing about the part numbers I needed for this Toyota; I hope this isn't one of those head scratching times. We'll see in a couple days Lord willing & the river don't rise.
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
