How tight is too tight?
Old 02-20-2011, 03:22 PM
wii_tarded's Avatar
How do you know when your fan belt is tight enough, and not too tight? I'm afraid of tearing something up if I over tighten my belts, but my alternator belt squeals at times, and my rpms were down to 250 this afternoon. The squealing doesn't last very long (just a second or two) but it's enough that it's annoying. Any help?
Old 02-20-2011, 03:47 PM
scuba's Avatar
Get a tension gauge and follow the FSM specs.....
Old 02-20-2011, 04:32 PM
sebastianholmes's Avatar
if your belt is tight and it still squeals then get a new one.. a GOOD quality one. if it still squeals then check your pullies.. my harmonic balancer was effed up and the alterantor pulley on it broke loose and wobbled when it reved up
Old 02-20-2011, 05:27 PM
corax's Avatar
I just go by feel, but I've been at it for a few years. Also, try to clean the serpentine pulley groves with a wire wheel. Rubber builds up in the groves over time and causes problems.
I've been known to hold a wire brush against the pulley while the engine is running because I'm lazy, try this method at your own risk.
Old 02-20-2011, 05:41 PM
85gijunk4x4's Avatar
x2, id try these to things
Old 02-21-2011, 02:47 PM
peow130's Avatar
Make sure you're also not leaking coolant or oil onto your belts. It makes one helluva racket.
Old 02-21-2011, 03:26 PM
blake.nemitz's Avatar
I've been known to hold a wire brush against the pulley while the engine is running because I'm lazy, try this method at your own risk.[/QUOTE]
i like your way of thinking but i would like to add do this on the coast side not right before the pulley
dzldust
7
10-06-2015 05:39 AM
gentry
09-28-2015 06:16 AM
PBRaddict#1
09-22-2015 07:50 AM
sonorn67
09-19-2015 05:39 PM
mordell
09-12-2015 10:13 AM
Quick Reply: How tight is too tight?
