Hour Meter, wiring to OEM oil pressure idiot light - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-17-2006, 09:37 PM   #1 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
So I am wanting to put an hour meter on my new truck and here is my idea for wiring..
Tap into the power for the OEM oil pressure light.. wire it to a relay then put the hour meter on the normally closed circuit, and the power coming from the acc position, when the key is on and the enigine isnt running the OEM light is on.. .hour meter wont be on... fire it up get pressure, light goes out.. hour meter comes on...
is my logic correct?
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 11-18-2006, 07:12 AM   #2 (permalink)
What 'hours' are you wanting to measure or record? ... Seems to me your proposed setup should work if you're specifically interested in 'number of hours the engine is operating at or above threshold oil pressure'.
Off the top of my head, though, it seems to me it'd be a lot simpler to wire the hour meter to an ignition-specific circuit if you'd be satisfied with 'hours the engine is turned on overall'.
EnolaGaia is offline
Old 11-18-2006, 07:24 AM   #3 (permalink)
AH64ID's Avatar
Is your low oil pressure light illumintated when your engine is at idle? Mine isnt, as its not supposed to. So this setup would record time anytime the engine is operating, which is my goal. Wiring into the ignition circuit would be much more difficult as you would have to find something that only has power with the engine running, not just in the "on" position, otherwise you would clock engine time anytime you are just rolling the windows up or down with the engine off...
__________________
-John
AH64ID is offline
Old 11-18-2006, 09:09 AM   #4 (permalink)
Staff
Yoda's Avatar
If you are tapping into the wire between the light and the oil switch, I think it would work. (relay grounds through the switch contacts, opens the relay, hour meter stops)
We have lots of equipment with hour meters, and most are wired to an oil pressure switch of their own.
Some are wired to an ign circ, and we have probs with guys leaving the ign on to listen to the radio......the hour meter keeps ticking and we have to change oil (most equipment is on a 200 hour schedule). The equipment only have ign, no accy circuit.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 11-18-2006, 10:35 AM   #5 (permalink)
reggie 00's Avatar
Send a message via AIM to reggie 00 Send a message via Yahoo to reggie 00
Not to question your reasons, but to find out if it is something that might benefit me also. Why do you want to run an hour meter? Like Yoda said on heavy equipment you do it to track maintenance because there is not odometer. what kind of preventative are you focusing on with the meter?
in other words whats the plan Stan?
__________________
'83 Truck 4x4 - 4" lift, downey header,, lots of stickers.
'90 Runner $600 project ,32's on black Steelies,Optima Red Top, 1.5" Balljoint Spacers, 80 series Coils, Sleeping/Storage Platform extravaganza
You know enough to be dangerous, get out the way before you break something i can't fix- Pops
Bah, you are such a moose...
Rota est Fun!
Quote:
Originally Posted by ChickenLover View Post
Just get a bowl full of it, and dip 'em in.
http://www.4x4support.com
reggie 00 is offline
Old 11-18-2006, 10:51 AM   #6 (permalink)
2KTacoma's Avatar
why don't you just use the tach signal wire to throw a relay to give power to the hour meter, thats how it rigged for both engines on our boat.
__________________
Silver 2000 Toyota Tacoma Extended Cab V6 5spd SR5
Now with URD short shifter and
Milled polyurethane shifter seat
Hella FF1000 Driving Lights
2KTacoma is offline
Old 11-18-2006, 02:31 PM   #7 (permalink)
Staff
Yoda's Avatar
We do have security vehicles that sit and idle for LONG periods of time. If I went by the odo reading on those, it would equal maybe a 10k mile oil change. Someone had done a study that said 200 hrs is aprox = to 3k miles, so that is what we plan.
Course, some of them come in for service 200 hrs past due
__________________
David
TLCA 14788
Yoda is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
oil pressure fuel cutoff switch wiring?? deserttoy84 84-85 Trucks & 4Runners 1 04-05-2007 07:44 PM
No Oil Pressure Light? milowilli 86-95 Trucks & 4Runners 7 03-07-2007 09:10 AM
oil pressure light, and knk sensor ttr125mar 86-95 Trucks & 4Runners 0 03-12-2006 01:18 PM
Auto Meter Electric Oil pressure/Water temp gauge sender install 1988 3.0 1st gen CappyKD 95.5-2004 Tacomas & 96-2002 4Runners 1 06-16-2004 07:42 PM
2009 InternetBrands, Inc.
