Great tip for DIY security device/ignition kill - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-25-2006, 06:55 AM   #1 (permalink)
nrgetic99's Avatar
Ok,
I am not going to give specific details in case the 'bad people' are surfing but I have two great tips that I checked last night.
1. Circuit opening relay.
I used this on my 93 and just did the same on my 98.
If you put a switch in the green/yellow wire (its a low voltage wire that is 5V and very low current) , the starter will not work and neither will the ignitiuon system. This realy prevents both the starter circuit and the ignition circuit from energizing.
Find this relay from your manual. Chase down the harness to a spot where you can cut in and then cover it back up with black insulating tape (ther are spots on the harness that have factory black wrap.
Wire in a hidden switch or an alarm operated relay.
Truck WILL not start if the supply in this line is interupted
2. Auto only
Shift interlock ECU.
You can cut the Green White wire and it works the same as having a stop lamp bulb out. You cannot shift out of Park.
Last night, I wired a switch to a pair of SPST relays. If I can find a DPDT relay, I will replace it and actually cut the circuit opening relay wire and the shift interlock wire and have them both operated via the relays and switch.
Once activated, truck won't start and cannot be shifted into neutral to roll it away.
Sorry for lack of specific detail but do your research, find a good location for you and its a 90 min job at best.
David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow
93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ...
03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-(
99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten
96 SR5 Dune... 1.5kw stereo
nrgetic99 is offline
Old 07-25-2006, 07:40 AM   #2 (permalink)
Toyota Punk's Avatar
Send a message via AIM to Toyota Punk
I like it! I remember hearing about the fuel pump wire and always wanted to do that. I like the idea of the shift ecu wire, nice one-two combo there!
__________________
- Vince
2001 4Runner SR5 4WD V6, Sport/Highlander Edition
Black · Optima Red-Top · Addco front bar · Sylvania Silverstars · Injen intake · 265/75 Bridgestone Deuller A/T Revo's
Webshots (please ignore the terribly quality cell-phone pics)
Toyota Punk is offline
Old 07-25-2006, 07:52 AM   #3 (permalink)
nrgetic99's Avatar
Quote:
Well, I may or may not have the fuel pump wire cut...can't tell all my secrets !
Nice thing is, fuel pump relay ALSO will not energize without circuit opening relay.
David
__________________
Old 08-04-2007, 03:32 PM   #4 (permalink)
rayl82's Avatar
Send a message via MSN to rayl82
shifter loce bypass
in regards to the shifter lock any good thief knows if you turn the ket to the on pos you can shift into nutral and start the truck as long as you dont go into park you are good to go if i am wrong please correct me
Quote:
Originally Posted by nrgetic99 View Post
Ok,
2. Auto only
David
__________________
89 runner on an 85 runner frame and front axle 3.5" lift suspension 31" A/T tires 1.5"wheel spacers on the front ez locker in the rear crossover high steer and oh ya 3.4L v6
85 Runner buggy in the works...
rayl82 is offline
Tags
cheap, circuit, diy, ecu, forum, highlander, ignition, interloc, kill, lamp, security, shift, stop, switch, toyota, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
WabFab=great customer service and great products!! ocdropzone Customer Feedback For Vendors 0 07-12-2007 08:00 AM
Security Device, Please help Identify keithguts Alarm Systems 8 11-23-2006 07:57 PM
Non-ipod music device oly884 Off Topic Talk 13 07-07-2006 12:40 PM
Great tip for 2nd Gen rear windows Firefyter-Emt 95.5-2004 Tacomas & 96-2002 4Runners 7 04-13-2004 04:36 PM
Great Hi-Lift tip.. Firefyter-Emt 95.5-2004 Tacomas & 96-2002 4Runners 2 03-18-2003 10:00 PM
2009 InternetBrands, Inc.
