which fuel for smog check? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-01-2008, 11:08 AM   #1 (permalink)
toyNG's Avatar
I have to get a smog check soon. I was wondering if I'd be better off using premium gas for the check? Also, should I have it done on a full tank or closer to empty?
__________________
1986 pickup 4x4 SR5, 5-spd, 33x10.5 BFG KM1 muds, 2" body lift, front and rear lockrights, 4.88s, 4.7 t-case with Dave'z twin stick, BudBuilt crossmember with 1" drivetrain lift, Downey grille guard and skid plate, TG sliders
Still needed: rear bumper (Marlin, TG, or Dave'z)
toyNG is offline
Old 10-01-2008, 05:09 PM   #2 (permalink)
Alex 400's Avatar
Quote:
my theory: just use regular gas, just make sure the engine is very warmed up, not just warmed up, but like driven around for a while. Seafoam is good for helping clear up emissions too. Next time you fill up, dump a can of seafoam in the tank. and run it through.
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6, 5-speed, 31/10.50-15 Toyo A/T, All Pro 1.5" coil springs, Bilstein front shocks, doetsch tech mv12's rears, MC heavy duty clutch, 2.25" Cat-back with 50 series Flowmaster 169,xxx miles
Quote:
Originally Posted by slisdexia View Post
I blame the automatic transmission for the wussification of America
Quote:
Originally Posted by toyminator2000 View Post
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE
Alex 400 is offline
Old 10-03-2008, 12:35 PM   #3 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
A few tips to passing smog tests:
Use a gas with an ethenol blend. In theory they burn cleaner.
run a can of seafoam through your gas tank and intake before hand.
Pump up your rear tires to 40psi
Drive the truck around for at least 20 mins before the test.
When im in the lineup to get mine done, I will usually sit with my rpms around 2000 to get everything nice and hot.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 10-03-2008, 02:02 PM   #4 (permalink)
toyNG's Avatar
I'm still a bit uneasy with the seafoam idea, because of the mixed results i've read on here. Maybe I'll try it if it doesn't pass the first time. The increased tire pressure is a good idea.
__________________
toyNG is offline
Old 10-03-2008, 02:18 PM   #5 (permalink)
Kinked's Avatar
x2 on what jay said. nice and hot with an ethenol fuel and you should be good to go
__________________
91 4Runner <- 3.0, Auto, Alpine IDA-X001 Head Unit, Alpine 4" Front Spkrs, Alpine 6X9 rear Spkrs
93 4Runner <- 3.0, Auto, Alpine Head Unit
92 S-10 Blazer <- Selling
Kinked is offline
Old 10-03-2008, 02:27 PM   #6 (permalink)
surf4runner's Avatar
depends if your an optimist or a pessimist...
use the same octane youve been using...i usually just fill up w/chevron and go in when its ~1/2 tank (either full or empty-your call )
to warm it up fully, a couple of full throttle runs is also beneficial
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 10-03-2008, 04:13 PM   #7 (permalink)
bigarms23's Avatar
87 octane and a full tank
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1972 stepside jimmy d44/d70 425hp
1995 green range rover
bigarms23 is offline
Tags
add, ca, check, checkpremium, empty, fill, fuel, full, gas, pass, premium, smog, tank, test, truckee
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Failed Smog Check igogusto 95.5-2004 Tacomas & 96-2002 4Runners 51 02-05-2009 04:53 PM
Failed SMOG Check. HELP Bassinfool 86-95 Trucks & 4Runners 9 09-29-2006 01:37 PM
Smog Check Passed Today... Noliwan 95.5-2004 Tacomas & 96-2002 4Runners 2 07-18-2006 10:21 AM
87 Corolla didnt pass smog check... cabbage Off Topic Talk 8 05-03-2004 05:54 PM
CA smog check vs. the deckplate mod TDiddy 95.5-2004 Tacomas & 96-2002 4Runners 0 05-06-2003 06:15 PM
2009 InternetBrands, Inc.
