front diff problem
Old Dec 2, 2008 | 10:57 AM
88yotasr5runner's Avatar
Question front diff problem
so i have recently developed a consistant nock in four wheel drive. i have a 86 3.0 4runner and i have a few questions. I thought it was the front u joint first so i replaced it and it still makes the same noise. If i leave the hubs unlocked and put it in 4wd(hi or low) it doesent make the noise. but with the hubs locked it makes the noise all the time.
1. do the 20re and 3.0 have the same gear ratio?
2. what could cause that noise?(i think it is coming from the diff itself)
3. could it be coming from the axles themselves?(the noise doesent change with relation to steering.)
Old Dec 2, 2008 | 04:03 PM
bump!!!!!
Old Dec 4, 2008 | 10:26 AM
anyone????
Old Dec 4, 2008 | 10:51 AM
4Crawler's Avatar
Gear ratio is independent of the engine type, varies with manual or automatic transmission and also in later models with the factory tire size:
- http://www.4crawler.com/4x4/4R_TechI...tml#DiffRatios
Could be the CV joints in the axles (feel them and check for play or binding while turning them by hand). Could be a chipped tooth on the ring or pinion gear (drain gear oil and check for metal chunks). Could also be worn spindle bushings.
lledwod
Aug 30, 2016 01:03 PM
shisha1999
Mar 16, 2016 12:25 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
