| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Flex-A-Lite Black Magic fan broken terminals..Any one else?
#2 (permalink) |
I believe that you can solder a new connection to it, but first you need to find what caused the over load to make it melt. Why did the inline fuse not do it job and prevent the meltdown?
always carry some zip ties for roadside repair
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#3 (permalink) |
I don't understand why the inline fuse didn't pop either... And the wiring WAS zip tied so it couldn't bounce around hardly at all (when plugged in there was about 1/2" of play in the wire only when it fell out did it have enough play to potentially touch metal). I had zip ties with me and I was able to put the wire safely out of the way for the drive home.. I could not perform road side repairs because the place where I was supposed to have the power plugged in into the fan was no longer connected to the fan.
And of course just after I post I find a related one.... http://www.yotatech.com/f123/e-fan-warning-116051/ Last edited by Turbo4Runner; 10-09-2007 at 12:24 PM. |
#4 (permalink) |
This seems to be a common problem with these electric fans. I was considering one, but the guy who was selling it, had the same issue. So what gives? Can the wiring harness just not handle the load?
__________________
Pioneer HU, Audiobahn 10.100watt Sub, Sirius, Cobra NWWXST CB W/ K40, Wolo Air horn, K&N FIPK,Tokico Trekmasters,Tundra TRDs, Revtec spacers w/extended studs,Energy bushings on steering rack /front swaybar,SS front diff. drop kit w/skid plate mod,OME 890 Rears with OEM LC Tokicos,Ebrake ext. bracket, BFG AT/KO's, ProComp 1078 Alloys, Magnaflow SS muffler, Hayden 1678 Tranny Cooler, 85watt Amber fogs, 7 Way R/V plugin. |
#5 (permalink) |
I think in my case the issue was not the harness but the board itself.
#6 (permalink) |
So for reference what I did to fix it was simply remove all of the cheap flex-a-lite control guts and wired in my own relay and switch and ran the fan directly. This allows for much higher gauge wire and stronger connections then the dinky stuff that came on there.
| Tags |
| 1998, 4runner, 60, black, controller, efan, fan, flex, flexalite, free, hayden, issues, lite, magic, repairs, replace |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Flex fan question. NOT flex-a-lite/electric fan | hockeytown9 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-12-2005 03:34 PM |
| Black Magic Flex-A-Lite electric fan - gas mileage improvement numbers? | Forerunner | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 09-03-2003 07:17 PM |
| Flex-a-lite fan | Murph | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 06-28-2003 05:18 PM |
| flex-a-lite fan | boss hog | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 03-24-2003 05:19 PM |
