Doomist's leaks - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-10-2007, 01:35 AM   #1 (permalink)
Doomist's Avatar
Send a message via MSN to Doomist
Doomist's leaks
I have a leak and its a pretty good leak, dad thinks it might be the brakes brother thinks its a seal. so what do you think! any helpfull suggestions?!
yummy!!!
__________________
92 ext cab
3.slow
5sp
stock 4.30 gears
4" trailmaster lift
3" PP bodylift
35x13.50 Toyo Open Country MTs
Doomist is offline
Old 04-10-2007, 01:40 AM   #2 (permalink)
ChickenLover's Avatar
Stick yer tongue on it.. Does it taste like brake fluid, or diff fluid?
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 04-10-2007, 02:03 AM   #3 (permalink)
jct61765's Avatar
Take the tire off.
__________________
2002 4runner sport 4X4
87,000 and counting
2007 Camry LE
I'm bitterly clinging to Guns and Religion" (and I'll keep the rest of the constitution too)
jct61765 is offline
Old 04-10-2007, 02:06 AM   #4 (permalink)
Doomist's Avatar
... when i dont have a garage or a shop... and a jack for that matter. its kind of hard. but i guess i can try! its going to be. Rain+hi-lift+mud=taking tire off
__________________
92 ext cab
3.slow
5sp
stock 4.30 gears
4" trailmaster lift
3" PP bodylift
Doomist is offline
Old 04-10-2007, 02:07 AM   #5 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
Quote:
x2 lol
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 04-10-2007, 02:12 AM   #6 (permalink)
Staff
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
thank you elton... your input means so much here on YT....
__________________
94 4runenr: all the good stuff.......
89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs.
81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s
pacific-crawlers.com
For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :)
Tofer is offline
Old 04-10-2007, 02:41 AM   #7 (permalink)
Staff
Tofer's Avatar
that so funny will someone please add that to their sig!
__________________
Tofer is offline
Old 04-10-2007, 02:50 AM   #8 (permalink)
Doomist's Avatar
done.
__________________
92 ext cab
3.slow
5sp
stock 4.30 gears
4" trailmaster lift
3" PP bodylift
Doomist is offline
Old 04-10-2007, 06:04 AM   #9 (permalink)
breknraj's Avatar
Don't forget a jack stand! They are pretty cheap, but great insurance for safety!
As to your problem - With the amount of fluid you have, my first guess would be the axle seal. There is definitely enough there to just get a smear on your fingertip, then give it a sniff. Gear oil has a very distinct (and nasty) odor to it, and you will be able to smell it, even with just a little on your finger.
Brake fluid will give you the immediate feeling of drying your skin when you touch it.
Do that simple test (you don't even have to jack it up), then start making your plans from there.
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire.
Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker.
breknraj is offline
Old 04-10-2007, 07:31 AM   #10 (permalink)
mt_goat's Avatar
Probably gear oil, if all that was brake fluid your reservoir would be about empty by now and you'd be stopping very slowly.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 04-10-2007, 07:37 AM   #11 (permalink)
PoleVaulter95's Avatar
i would vote for it being a bad seal because ive been in the same position. but regardless of what it is your going to have to put on new shoes becuase they have been soaking in that oil. be prepared to thouroughly (sp*) clean out the inside of that drum so your braking wont be altered.
__________________
95 4runner 3.0 auto downey torsion bars and hd springs 32 khumos and way to much spray paint
PoleVaulter95 is offline
Old 04-10-2007, 07:43 AM   #12 (permalink)
techno's Avatar
While you are trouble shooting your problem, (touching, licking, smelling) I had the same issue once. Turned out to be from a dog taking a leak on my wheel....
...and yeah, most likely an axle seal.
__________________
00 4Runner SR5 4x4
techno is offline
Old 04-10-2007, 07:43 AM   #13 (permalink)
86SR522REEFI's Avatar
Send a message via AIM to 86SR522REEFI
Check your brake fluid level, is it low? Do the smell check. Is your brake pedal spongy? My truck was that bad when my wheel cylinder went. Good luck. O yea, make your way down to sears and get a floor jack and a jack stand set
__________________
<(((Mark)))>
1997 4x4Runner
Limited 5-VZE
Auto 134,000 Miles
Quote:
Originally Posted by Leslie Nielsen
I am serious, and don't call me Shirley.
86SR522REEFI is offline
Old 04-10-2007, 08:20 AM   #14 (permalink)
Rcross's Avatar
If it was gear oil you should be able to smell it just getting around 20 ft of your truck......
__________________
Certified Jeep recovery specialist
We live in the land of the free, only because of the brave.
If you can't fix it with a hammer, what you have is an electrical problem.
If you want to find out what happens when you don't have control of your immigration, talk to an Indian.
Rcross is offline
Old 04-10-2007, 12:48 PM   #15 (permalink)
WSUWESTON's Avatar
I vote for the dog piss
WSUWESTON is offline
Old 04-10-2007, 10:35 PM   #16 (permalink)
Doomist's Avatar
thats kind of weird. the day i found this leak, i was at a freinds boat.. and a dog... took a leak on my tire! !!. thats scarey.
__________________
92 ext cab
3.slow
5sp
stock 4.30 gears
4" trailmaster lift
3" PP bodylift
Doomist is offline
Old 04-10-2007, 10:37 PM   #17 (permalink)
so did u smell it yet
__________________
<(((Mark)))>
1997 4x4Runner
Limited 5-VZE
Auto 134,000 Miles
Old 04-10-2007, 10:45 PM   #18 (permalink)
msw0085's Avatar
Send a message via AIM to msw0085
Quote:
Originally Posted by Elton View Post
x2 lol
sorry, i have one more post till 2000
__________________
TOYOTA|moving forward
1996 3.4 Litre | 4-Wheel Drive | 5-speed Manual Transmission | Magnaflow Exhaust
Deckplate | Intake Silencer Removal
*MasterDebater*
msw0085 is offline
Old 04-11-2007, 12:44 AM   #19 (permalink)
Doomist's Avatar
Yea i smelt it, it smells like hydroil oil. (closest thing i could think of) but i opened the diff today, and oil started coming out.. and with a closer look, it has bubbles in it. dont know if thats good or bad. the brake fluid is fine. its at where i filled it last.
__________________
92 ext cab
3.slow
5sp
stock 4.30 gears
4" trailmaster lift
3" PP bodylift
Doomist is offline
Old 04-11-2007, 12:50 AM   #20 (permalink)
Staff
Tofer's Avatar
sounds like my suggestion to do the diff breather mod last summer was a good one........ too bad it fell on deaf ears
your diffs full of water... the pressure built up and blew the seal..... thats my call
__________________
Tofer is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Coolant leaks and oil leaks on a 91 4runner L33mur 86-95 Trucks & 4Runners 5 05-21-2007 01:37 PM
Doomist's Rig Doomist 86-95 Trucks & 4Runners 24 06-19-2006 11:12 PM
Leaks? stevrock 86-95 Trucks & 4Runners 12 04-24-2006 02:00 PM
She Leaks Duec66 95.5-2004 Tacomas & 96-2002 4Runners 20 09-28-2005 06:59 AM
97 4Runner rear axle leaks - HELP an Aussie !! R cannot stop leaks !!! beddo 95.5-2004 Tacomas & 96-2002 4Runners 8 08-06-2004 05:48 PM
2009 InternetBrands, Inc.
