YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 11-03-2006, 03:43 AM   #1 (permalink)
Differential / Transfer Case Fluids
I finally decided to change the fluids in my diffs & xfer case last night. I've only had it ('02 limited) a year, it has 104,000 miles, and I'm pretty sure they've never been changed. First problem is I couldn't get the fill plug off the rear diff. Luckily I hadn't remove the drain plug, so I'll tackle that another day. Transfer case fluid didn't look too bad for 104k miles, but when I drained the front it was dark grey and there was something resembling grease on the end of the drain plug. Anybody know what that might be? I wiped it off and refilled the diff with Amsoil Severe Gear and drove it about 25 miles. I put it into "4wd" several times and everything seem fine.
__________________
'02 4-Runner Limited
Stock
smccollamjr is offline
Sponsored Links
To remove this ad, register today!
Old 11-03-2006, 05:17 AM   #2 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
You need a breaker bar to get the fill plug off (more leverage) but don't round off the corners. Then I'd suggest replacing the fill/drain plugs on everything with these...much easier to get on/off. I replaced all of mine on both vehicles, 85 and 87.
The stuff on the end of the drain plug was fine metal shavings pieces that collected on the magnet...which is normal.
http://www.wabfab.org/products/diffe...ferentials.htm
waskillywabbit is offline
Old 11-03-2006, 05:51 AM   #3 (permalink)
Crux's Avatar
Make sure you use a 6pt 24mm socket instead of a 12pt 24mm so you don't round the rear diff plug.
__________________
97 4Runner SR5 Blue - 135k miles, E-Locker, Armorology front/rear bumpers & sliders, BudBuilt skidplate+belly, MTR 285/75/16s, 2" Tundra/OME Lift, 1" 4Crawler Bodylift, 1" diff drop, Black Aluminum Wheels, Cobra CB
99 4Runner SR5 Black - 57k miles, E-Locker, Daily Driver
06 Girl - destoyer of all things fragile
08 Boy - a fat little hairy sumo wrestler
Crux is offline
Old 11-03-2006, 08:00 AM   #4 (permalink)
I was hoping it was just shavings, but it looked like grease to me. I'm anxious to see what the rear looks like.
All I had was a 12pt and I had read warnings about rounding the plugs. That's why I didn't try the breaker bar. I'll try to find a 6pt 24mm (two Sears stores haven't had them) and use a breaker bar. The ones on the transfer case came off fairly easy.
Will the part from WABFAB fit the rear fill & drain holes? Do I need the steel or aluminum washers?
Thanks for all the help.
__________________
Stock
Old 11-03-2006, 08:10 AM   #5 (permalink)
Sponsoring Member
Talking
Yep, they'll work flawlessly. I even sell the 10mm allen head socket.
From the website:
"Magnetic Drain Plug
Magnetic Drain Plugs are a great way of keeping metal from building up in the oil. Low profile design uses recessed 10mm Allen socket. Your choice of Aluminum or steel washers. Aluminum washers are designed for transfer cases, and aluminum transmissions (G, W & R series). Steel washer is designed for axle housings (differentials) and steel transmissions (L series)."
Old 11-03-2006, 08:13 AM   #6 (permalink)
gregbreakseverything's Avatar
When i changed my diff oil, I thought that was silicone or grease at first. Then after playing with it, I found out it was just metal filings in oil. Cool stuff.
__________________
-Greg
Sold- 85 4wd toyota pickup. Stock and sweet!
'99 SR5 - Deckplate, ISR, Sweet stereo, all synthetic, KC day lighters, headlight wiring harness, Sonoran Steel #7, 285/75's.
gregbreakseverything is offline
Old 11-03-2006, 03:42 PM   #7 (permalink)
Nic
Nic's Avatar
I changed mine and had the same thing on the drain plug. Don't sweat it. Like already said, most of it is very fine metal shavings.
I didn't have any problems lossening the plugs. I used a 6 point socket with and actual breaker bar and had absolutely no problems. I know you never can tell, but I bet if you get a 6 pt socket and decent breaker bar, it will come off easily.
I changed mine about this time of year. I learned one thing-do it when it is warmer. It is sooo much easier to pump the gear oil when it is warmer outside.
__________________
Nic
1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed
Nic is offline
Old 11-06-2006, 04:19 AM   #8 (permalink)
The only place that I found a 6pt 24mm was a deepwell at Advanced Auto Parts. I looked everywhere 2 so I thought I would give you a heads up.
automated11 is offline
Old 11-06-2006, 04:32 AM   #9 (permalink)
4Crawler's Avatar
I use a metric impact socket set I got from Harbor Freight, 10-24mm, all 6 sided, 1/2" drive:
http://www.harborfreight.com/cpi/cta...temnumber=7383
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Transfer case ??? Lunnzz 86-95 Trucks & 4Runners 9 12-15-2006 01:00 PM
Help with fluids for diffs & xfer case on '98 Tacoma TRD TahoeEd General Vehicle Related Topics (Non Year Related) 6 12-07-2006 06:46 AM
Servicing the differential/transfer case? dynamo 95.5-2004 Tacomas & 96-2002 4Runners 27 02-21-2005 04:55 PM
Transfer case bayrunner 95.5-2004 Tacomas & 96-2002 4Runners 1 05-05-2004 08:52 PM
Transfer Case Eighty7ToyTruck 95.5-2004 Tacomas & 96-2002 4Runners 0 03-05-2003 01:33 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
