YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-11-2008, 04:05 PM   #1 (permalink)
89dlx's Avatar
difference in transmissions?
I have a 1989 22RE 4X4 pickup (W56).
I also have a 1995 3.0V6 4X4 pickup (R150F).
What's the difference between the two transmissions? Is it just transfer case shifting (top - forward) or is it something else? Is the R150F an improvement over the W56? If the difference is just bellhousings, can't you swap them?
89dlx is offline
Sponsored Links
To remove this ad, register today!
Old 05-11-2008, 06:33 PM   #2 (permalink)
tc
tc's Avatar
The R150 is one of the strongest transmissions Toyota ever made.
The only way to mate one behind a 4cyl is with a bellhousing from a turbo truck ... and they are rare.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 05-11-2008, 06:36 PM   #3 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
I would stick with the W56. The gear case is much stronger IMHO and gearing can be changed if you ever want to upgrade for wheeling.
However, TC is correct you will need an R151F bellhousing (turbo truck) to mount the V6 trans/case combo, as well as having your driveshafts redone.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by bigtrucknwheels View Post
you better watch out, you mess with the coug, and your world is gonna get turned upside down. Just ask Chuck Norris. Deathcougar is the only man alive to ever beat Chuck Norris.
Quote:
Originally Posted by Kaydon
You are about as entertaining as a child's inflatable punching toy. You bop it, it springs back, you bop it again and you forget it ever existed. It slowly deflates in an unused corner, then one day you throw it away.
DeathCougar is offline
Old 05-11-2008, 06:38 PM   #4 (permalink)
tc
tc's Avatar
I think you mean gear drive case.
I disagree about being stronger, but can't argue about the lower gears... chain drive cases are holding up just great behind 4.7 crawl boxes in supercharged Tacos making way more power/torque than a 22RE will ever dream of ...
__________________
tc is offline
Old 05-11-2008, 06:41 PM   #5 (permalink)
shoot i meant gear drive
its my birthday and I have been drinking, leave me be! lol
__________________
Old 05-11-2008, 09:47 PM   #6 (permalink)
cosmo's Avatar
W56: Rev:-4.091
1st: 3.954
2nd: 2.141
3rd: 1.384
4th: 1
5th: 0.850
R150F: Rev: -4.220
1st: 3.830
2nd: 2.062
3rd: 1.436
4th: 1
5th: 0.838
The R150F is stronger. When Toyota introduced the Turbo Truck and 4Runner
in 1984, they developed the R150F, a 4WD version of the R150. It is typically connected to stronger differentials as well. It was a natural carryover to the V6 models in 1988.
__________________
'93 4WD Truck (22R-E/W56)
'99 Tacoma 4WD SR5 (5VZ-FE/R150F)
cosmo is offline
Old 05-12-2008, 07:23 AM   #7 (permalink)
Red_Chili's Avatar
The R151 is stronger and has a significantly lower first gear - but due to that (per Marlin) it will not shift as nicely as the W56. The newer R150s shift better than both and share the strength of the R151. The chain transfer case is not in fact weaker, but the geared case can be regeared which is huge. A geared tcase can be bolted on to any R150, however, with a Marlin adapter.
If I had it to do over, I might have gone with the R150 behind my donor 1996 instead of the R151, and just used the adapter for a Marlin Ultimate. But it works fine and I like the low first when towing and in sticky situations wheeling.
__________________
-Bill
Red Chili II: 1987 SASed 5VZ-FE 4Runner with more stuff than I can afford. Not that that makes me unique 'round here.
BlackBean: 1997 Taco 3RZ-FE auto XtraCab DD. Going to my son. It's an ok truck.
Shadowfax: 1993 minitruck. Getting the Engnbldr full meal deal. Hunting truck and DD!
Bio Page
Red_Chili is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
transmissions camo31"10.50" Newbie Tech Section 2 11-15-2007 08:45 PM
transmissions olharleyman 86-95 Trucks & 4Runners 3 04-26-2007 04:09 PM
What transmissions? scenarioL113 95.5-2004 Tacomas & 96-2002 4Runners 5 03-19-2007 03:42 AM
Tundra Transmissions??? corvettelvr73 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 1 04-30-2004 05:08 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
