Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
difference in transmissions?
I have a 1989 22RE 4X4 pickup (W56).
I also have a 1995 3.0V6 4X4 pickup (R150F). What's the difference between the two transmissions? Is it just transfer case shifting (top - forward) or is it something else? Is the R150F an improvement over the W56? If the difference is just bellhousings, can't you swap them? Last edited by 89dlx : 05-11-2008 at 04:06 PM. |
| Sponsored Links |
#2 (permalink) |
The R150 is one of the strongest transmissions Toyota ever made.
The only way to mate one behind a 4cyl is with a bellhousing from a turbo truck ... and they are rare.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#3 (permalink) | ||
I would stick with the W56. The gear case is much stronger IMHO and gearing can be changed if you ever want to upgrade for wheeling.
However, TC is correct you will need an R151F bellhousing (turbo truck) to mount the V6 trans/case combo, as well as having your driveshafts redone.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts! Quote:
Quote:
#4 (permalink) |
I think you mean gear drive case.
I disagree about being stronger, but can't argue about the lower gears... chain drive cases are holding up just great behind 4.7 crawl boxes in supercharged Tacos making way more power/torque than a 22RE will ever dream of ...
__________________
#5 (permalink) | ||
shoot i meant gear drive
its my birthday and I have been drinking, leave me be! lol
__________________
Quote:
#6 (permalink) |
W56: Rev:-4.091
1st: 3.954 2nd: 2.141 3rd: 1.384 4th: 1 5th: 0.850 R150F: Rev: -4.220 1st: 3.830 2nd: 2.062 3rd: 1.436 4th: 1 5th: 0.838 The R150F is stronger. When Toyota introduced the Turbo Truck and 4Runner in 1984, they developed the R150F, a 4WD version of the R150. It is typically connected to stronger differentials as well. It was a natural carryover to the V6 models in 1988.
__________________
'93 4WD Truck (22R-E/W56) '99 Tacoma 4WD SR5 (5VZ-FE/R150F) |
#7 (permalink) |
The R151 is stronger and has a significantly lower first gear - but due to that (per Marlin) it will not shift as nicely as the W56. The newer R150s shift better than both and share the strength of the R151. The chain transfer case is not in fact weaker, but the geared case can be regeared which is huge. A geared tcase can be bolted on to any R150, however, with a Marlin adapter.
If I had it to do over, I might have gone with the R150 behind my donor 1996 instead of the R151, and just used the adapter for a Marlin Ultimate. But it works fine and I like the low first when towing and in sticky situations wheeling.
__________________
-Bill Red Chili II: 1987 SASed 5VZ-FE 4Runner with more stuff than I can afford. Not that that makes me unique 'round here. BlackBean: 1997 Taco 3RZ-FE auto XtraCab DD. Going to my son. It's an ok truck. Shadowfax: 1993 minitruck. Getting the Engnbldr full meal deal. Hunting truck and DD! Bio Page |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| transmissions | camo31"10.50" | Newbie Tech Section | 2 | 11-15-2007 08:45 PM |
| transmissions | olharleyman | 86-95 Trucks & 4Runners | 3 | 04-26-2007 04:09 PM |
| What transmissions? | scenarioL113 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-19-2007 03:42 AM |
| Tundra Transmissions??? | corvettelvr73 | 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 | 1 | 04-30-2004 05:08 PM |
