| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
coolant in water..again...
#2 (permalink) |
Staff
I would run it a short time and dump the oil and change filter. Refill and run again. Residual water can make it look like it is still leaking.
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) Last edited by Yoda; 03-06-2006 at 08:07 PM. |
#3 (permalink) |
thanks for the advice, i tried that i have run 8 qts, 2 filters and many gallons of water... thanks anyway
#4 (permalink) |
Similar issues with my truck before I got it. BOTH PO's replaced the HG with no fix. Turned out to be a leak in the TC cover gasket and a weep in the freeze plug ("molly plug??) under the cam (in the head).. Not the HG as suspected.
__________________
'93 FZJ80 Elockers, MAF/OME lift, 35" TrXus MT's, TJM Front Bumper, RockDog4x4 Custom Rear Bumper '06 4Runner SR5 V8 Yankee Toys |
#5 (permalink) |
i changed the timing cover and gasket when i replaced the head. Thanks again for the help though! anyone else know anything? if i have a cracked block would that be doiing this? i checked compression and all seems fine? im lost!
#6 (permalink) |
Did you check to see if your block was warped
Have you pressure tested the the cooling system, if it doesn't hold pressure, you can check to see if it's leaking into the cylinders by pulling the sparkplugs and stuffing strips of cloth down to see if they get wet. |
| Tags |
| dave, emunclaw, morin, wa |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Do You Need Distilled Water For The Coolant? | jim628 | 95.5-2004 Tacomas & 96-2002 4Runners | 25 | 05-18-2007 03:58 PM |
| Coolant or water in the vacuum lines(metal tubes) for '85 22RE EGR | pcmentor | 84-85 Trucks & 4Runners | 2 | 11-10-2006 08:07 AM |
| coolant/water temperature gauge help | typical8o8 | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 10-06-2006 06:32 PM |
| 22re losing coolant, coolant tank bubbling | shwuz | 86-95 Trucks & 4Runners | 15 | 07-25-2006 07:57 PM |
| My coolant overflow is spewing coolant? any suggestions on what it might be? | wimpywade94 | Maintenance & Repair Archives | 8 | 07-19-2003 11:50 AM |
