| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
clutch? whats the best type to get and where
Last edited by waskillywabbit; 04-09-2009 at 08:12 PM. Reason: Title clarity per posted sticky |
#2 (permalink) |
i like the clutch i got from marlin crawler
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1972 stepside jimmy d44/d70 425hp 1995 green range rover |
#3 (permalink) |
Get an exedy clutch from anywhere for about $90. Exedy is an OEM to many japanese car companies. Some TRD clutches are made by Exedy.
__________________
- Brian 84 toy pickup mostly stock |
#4 (permalink) |
Location: Vacaville/Sierra Nevada Mountains, CA/ UNLV (Las Vegas), NV
I got my clutch kit from Kragen for $120 its been workin great! I don't remember what type it is though. It came with a clutch disc, pressure plate, throw out bearing, pilot bearing, and alignment tool. Make sure you replace all of those as well as resurface your flywheel when you do it. Another idea, replace the rear main seal...they tend to leak after a while and while you're there you might as well.
__________________
'89 Beater Jeep Eater in progress 4.88's, TRD e-locker, Dual Cases, 33's, Armored, Tread Lightly Mixchallenge.info |
#6 (permalink) |
im gonna be needin a new clutch..but i also need a new flywheel..mine has heat cracks allll in it..lol..
anybody know of a clutch kit that comes with a new flywheel...thats not expensive? or where i can get a GOOD cheapish flywheel..
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#7 (permalink) | |
Quote:
http://marlincrawler.com/clutch/flyw...faced-flywheel
__________________
#8 (permalink) |
Having driven an "OEM replacement" clutch and my truck with a Centerforce, I'd recommend popping for the better aftermarket one if you can spare the little bit extra. The oem clutch I drove felt HORRIBLE! Really grabby. I've driven trucks with both my lower end centerforce and the top of the line one, both are great feeling and last longer than stockers.
__________________
'85 Xtra Cab Knobbly tires and such things. |
#9 (permalink) | |
Quote:
| Tags |
| 20r, 4x4, 89, centerforce, clutch, kit, las, nevada, oem, plate, pressure, problems, rated, top, toyota, vegas, whats, yotatech |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| soft clutch pedal (but new clutch -toy oem) | idanity | 86-95 Trucks & 4Runners | 2 | 01-18-2009 10:37 PM |
| Soft clutch after replacing clutch bracket and other issues | Fo by Fo | 86-95 Trucks & 4Runners | 2 | 01-06-2009 08:45 PM |
| Clutch grinding, poor shifting, cracked clutch pedal bracket | T100NewMexico | 93-98 T100s | 10 | 09-22-2006 01:31 PM |
| Will the height adjustment of the clutch pedal affect the wear of the clutch? | YotaJunky | Maintenance & Repair Archives | 6 | 11-21-2005 08:03 PM |
| Napa Clutch vs. Toyota Clutch (94 SR5 4x4) | sunflower | Maintenance & Repair Archives | 8 | 05-08-2005 01:57 AM |
