Can a Novice Install 22RE Rebuilt Long Block
Howdie Doodie, and thanks in advance for your qualified replies.
I have a 94 4Runner with 22re. It has had a knock for 3 years (probably wrist pin, I'm told), that has been well managed with 2 qts Lucas at each oil change. Recently, it threw the water pump belt, engine overheated, but never redlined, and someone convinced me I needed a new head gasket (without planning the head - dumb I know). Oh-la-la, should have gone with just the belt first, to see. It runs, but has low compression (90's in 3 and 4). Cylinders looked great, pistons very clean for 210k.
My questions; Can a mechanically inclined guy, having only swapped out a beetle long block, install a rebuilt 22re long block? What do I need to have (tools), and what manuals would be essential to get the job done? And, not knowing when the clutch was last replaced (I'm second owner of a well taken care of Toy, with 50k on my end), replace the clutch disk while swapping blocks?
What I would do on break down is clearly label everything, package it up, number it, and then reverse the order during install. Voila! I can take video also. I still get 2 year 24k warranty, assuming they don't find a way out.
Thanks - and lookin forward to your replies.
Staff
A member on here a few years ago never changed his own oil and did it. You would be able to https://www.yotatech.com/forums/f116...cement-212688/
As with everything it's best to document thoroughly
Especially if you have CRS like me.
You didn't mention whether it's the DD, which might tend to make you rush.
If I had the cash a Long Block, that's what I would have done, so except for block out and block in I did the same on my 91 P/U,
asking plenty questions and using this great resource here.
Document everything, make use liberally of the digital camera and lots of gallon zip lock freezer bags w/ sharpie pen.
Keep it clean, makes it a lot easier.
The Haynes manual turns out has some shortcut/overlooked issues which can all be answered here.
Wish the FSM had pictures instead of sketches.
Buy a torque wrench and penetrating oil and use them.
Good Luck keep us apprised of progress.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
jon.r
07-11-2015 03:34 PM
