Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Best way to remove tie rods
Yep, what do you guys think is the best way to remove tie rods WITHOUT buggering up the boots... I need to swap mine around since sombody put them in backwards...
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
| Sponsored Links |
#2 (permalink) |
BFH hit the part that dosnt move, the part that doesnt have a rubber boot. hit it fro the side, with a large hammer until it comes loose.
__________________
1984 toyota pickup extended cab 4x4 couple of mods |
#3 (permalink) |
I have used this method with some success.
Remove the castle nut then reistall it upside down although only threaded on far enough to protect the threads, then smack it with a hammer. Installing the castle nut upside down allows you to protect the threads without sacrificing the lugs on the castle nut. Hope this makes sense.
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks? Idiocracy (edited for family friendly viewing) Last edited by zlathim : 08-25-2008 at 07:12 PM. |
#4 (permalink) |
Sponsoring Member
Good gosh people...use a small pitman arm puller/TRE puller. Piece of cake with no "beating" anything.
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab 6th Annual South East 4Runner Jamboree, May 22-25, 2009 WabFab Off-Road Salvation Army Online Kettle |
#5 (permalink) |
X2 you can probably get to use one for free from from a chain parts store, advance or schucks.
#6 (permalink) |
Hit the ear where the tie rod goes into with a hammer. This will break the taper and it will come free. No special tools needed just aim.
James
__________________
2nd gen power mirrors for sale http://www.yotatech.com/f109/2nd-gen.../#post50746877 New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569 Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/ |
#7 (permalink) |
Well I tried beating on it.. Spent a good 10 mins wailing on the mofo, smothered it in pb blaster too... So thats not working....
I guess im off to the parts store for a new tool (wooo)... unfotunatly no one around here has loner programs like the stores in the us do....
__________________
#8 (permalink) |
Princess Auto has the tools for a good price.
__________________
'91 4Runner SR5 V6 4X4 Auto, A/C (self installed) 4.56, 31x10.5x15 Nokian Vatiiva Tires Taurus fan (removed) '90 4Runner SR5 V6 4X4 Auto, A/C, 4.56 V6 power with V8 fuel mileage I've used Fram oil filters and dino oil in all my stuff for 30 years and never had trouble |
#9 (permalink) |
yea probably not a bad tool to carry in your box (TRE puller)....I usually carry a couple spare rod ends too
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#10 (permalink) | ||
try heating it...and then beating it. It's tough to do without burning the boot, but if careful it can be done.
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock. It's becoming an addiction. |
#11 (permalink) | |
They sure do! Too bad the closest one is about 35 mins from me...
Quote:
I was tempted to break out the torch, but I didnt want to risk burning the boot off....
__________________
#12 (permalink) |
boots are cheap
pickle fork!! |
#13 (permalink) |
X3, use a puller.
__________________
Dale 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#14 (permalink) | |
Quote:
Definitely - they are all the same size, so the one tool let's you do it all.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#15 (permalink) | |||
Quote:
.....for that matter....what the hell were they smokin if they did the inners wrong?...I want some too...lol![]()
__________________
Quote:
#16 (permalink) | |
best way to remove them, sas!
jk. i need to replace mine too, probably get a tie rod end puller.
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear Quote:
My build thread http://www.yotatech.com/f152/904_run...thread-158746/ |
#17 (permalink) | |
Quote:
My old tie rods were in the same way so we just put them in like that.... oops!! Regaurdless of what we were smoking ![]() The only problem this has caused was clearance issues once I go offroad and everything flexes. Hey 904_runner - A sas is very much in my mind. I almost want to do it just to get rid of the pain in the arse IFS crap. I cooked yet another idler arm. In one day of mild wheeling. That downey brace is usless!!!!
__________________
#18 (permalink) | |
how, snapped it in half?
oh sas, might as well (thinking to myself) i just spent over $350 on books, that could have been a dam axle. son of a ^%&(%
__________________
