Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Balancing Black Wheels??
So if you buy black wheels how are they balanced without the wheel weights sitting on the outside of the wheel?? I mean, you wouldn't get black wheels and put a silver weight on the outside of the wheel would you?
I know a wheel can be balanced just on the inside of the wheel but is this as good of a balance job? Do you just paint the weights? I'm just curious as to how you keep your black look with silver weights. Thanks!! |
| Sponsored Links |
#2 (permalink) |
have them use tape on weights on the inside of the wheel. works just as well as clip on weights, they just tend to fall off quicker
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22RE 258,000 miles on original motor pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#3 (permalink) | |
dynabeads might be somthing to look into
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear Quote:
My build thread http://www.yotatech.com/f152/904_run...thread-158746/ |
#4 (permalink) |
blancing powder
__________________
Just dropped in to see what condition my condition was in. |
#5 (permalink) |
I had mine balanced at a local shop, they had black weights on hand
__________________
2006 Tacoma SR5 - Stock for now 2000 4Runner Limited 16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~Goodridge Front and rear brake lines~Rear Locker Mod~Rear Diff Extended~Surco Safari Rack~ Optima Yellow Top~ Trail Gear Sliders~6 100W Hella 500's~ Deckplate Mod w/ True Flow~ISR Mod~~Autometer Volt and Oil Press gauges~Satoshi Grille~Redline Hood Lift~Hayden 1678 Aux Cooler~Safari Snorkel |
#6 (permalink) |
fill them with water, lower center of gravity.
__________________
2003 4RUNNER LTD V6 FUSION LIFT/COOPER ATR/CAI/AMSOIL Technical skill is mastery of complexity while creativity is mastery of simplicity." |
#7 (permalink) |
sharpee.
__________________
1988 4runner::SAS|3vze|A340H|5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|Custom CV rear driveshaft from High Angle Driveline|Rear D/S shortened and made into front D/S |35" Goodyear MT/R My 4runner n stuff |
#8 (permalink) |
Coming from someone who works at a wheel/tire shop, balancing with lead pound on weights give much better results then the tape-weight. Tape-weights are great for passenger car tires. If you are try tape-weighting a light truck tire, you will end up using more weight then it is worth.
__________________
Run it 'till it wont! |
#9 (permalink) |
The shop that mounted my BFG's put the weights on the inside of the rim. Its nice not having to stare at ugly grey weights on the outside rim..
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#10 (permalink) |
Tape weights then black duct tape over top. I saw a bunch of JGTC cars using this simple fix at the race in Fontana 4 years ago. Works fantastic.
#11 (permalink) |
yeah. just tell them to dynamic balance them.. static balance sucks...
__________________
#12 (permalink) |
I couldnt stop laughing for some reason when I read the thread title...
anyways....balancing powder sucks..if it gets wet it can clump and also can clog the valve stem if it decides to find its way out... Try Dynabeads from Innovative Balancing if anything....thats what semi truckers use. I use them on my 36" swampers...never required any additional weights or balancing and I can run em at 80 miles per hour..FWIW
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#13 (permalink) | |
Quote:
BTW Collier, when you get a chance I'd like to buy that CV axle. ![]()
__________________
Dale 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#14 (permalink) | |
Quote:
sorry man i have been really backed up lately dale....I will get back to you very soon i promise ![]()
__________________
#15 (permalink) | |
Quote:
__________________
#16 (permalink) |
Be sure when you get them balanced wether your gettin them static balanced or dynamic ask the tire shop to use exact balancing. The best method of all is road force balancing. That way costs a little more because the tire has to me mounted a dismounted twice to line up the high and low spots of the tire and rim. I work at goodyear and have done that to my ltbs on steelies and i got my down to lesst that 2.5 onces total on each tire.
__________________
Myspace 94 p/u, 5 inch trail gear sas, Marlin Crawler Drop in 3rd with 5.29 gears and spool, shakles, 33x13.50s Super Swampers LTBs, 15' Steel Wheels, ARB Bull Bar Bumper, Warn M8000 winch, Warn Premium Hubs, 50 watt backup lights mounted on toolbox, Chip, K&N Air Filter, Animal House Horn, Cobra CB, Sun Pro Super Tach, Hurcliner,Turbo Muffler NO LIMIT 4X4 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Balancing steel wheels vs. aluminum | regularguy412 | Tires & Wheels | 9 | 04-29-2006 07:50 PM |
| Should I get black wheels? | grimpy | 95.5-2004 Tacomas & 96-2002 4Runners | 42 | 04-16-2006 05:49 PM |
| Black wheels... | Tacoma750 | General Vehicle Related Topics (Non Year Related) | 33 | 02-08-2006 07:54 AM |
| green 2nd gen with black wheels vs. silver wheels | Exeter | 86-95 Trucks & 4Runners | 8 | 02-08-2006 01:06 AM |
| Black wheels for snow wheels.. me like! | UKMyers | 95.5-2004 Tacomas & 96-2002 4Runners | 21 | 12-13-2004 10:32 PM |
