YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Tires & Wheels
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-25-2008, 01:23 PM   #1 (permalink)
Balancing Black Wheels??
So if you buy black wheels how are they balanced without the wheel weights sitting on the outside of the wheel?? I mean, you wouldn't get black wheels and put a silver weight on the outside of the wheel would you?
I know a wheel can be balanced just on the inside of the wheel but is this as good of a balance job?
Do you just paint the weights?
I'm just curious as to how you keep your black look with silver weights.
Thanks!!
Quattro15 is offline
Sponsored Links
To remove this ad, register today!
Old 08-25-2008, 02:03 PM   #2 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
have them use tape on weights on the inside of the wheel. works just as well as clip on weights, they just tend to fall off quicker
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22RE 258,000 miles on original motor
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 08-25-2008, 02:20 PM   #3 (permalink)
dynabeads might be somthing to look into
__________________
1990 4runner SR5, 3.0 with 254K, 5-speed, 4.56 gears, , Rancho 9000's, 33X12.50's trxus mt's, rear lock right, 4" lift with lc coils in rear
Quote:
Originally Posted by 4rnr View Post
I have NOOO $$ Im a poor college kid I recently started working so I decided to SAS.
If I dont sas Ill just waste money on chili cheese dogs and beer then Ill be poor, fat, and STILL on ifs.
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
904_runner is offline
Old 08-25-2008, 02:22 PM   #4 (permalink)
blancing powder
__________________
Just dropped in to see what condition my condition was in.
pyro is offline
Old 08-25-2008, 03:46 PM   #5 (permalink)
OSU4Runner's Avatar
Send a message via AIM to OSU4Runner
I had mine balanced at a local shop, they had black weights on hand
__________________
2006 Tacoma SR5 - Stock for now
2000 4Runner Limited
16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~Goodridge Front and rear brake lines~Rear Locker Mod~Rear Diff Extended~Surco Safari Rack~ Optima Yellow Top~ Trail Gear Sliders~6 100W Hella 500's~ Deckplate Mod w/ True Flow~ISR Mod~~Autometer Volt and Oil Press gauges~Satoshi Grille~Redline Hood Lift~Hayden 1678 Aux Cooler~Safari Snorkel
OSU4Runner is offline
Old 08-25-2008, 05:11 PM   #6 (permalink)
DIHOWARD's Avatar
fill them with water, lower center of gravity.
__________________
2003 4RUNNER LTD V6
FUSION LIFT/COOPER ATR/CAI/AMSOIL
Technical skill is mastery of complexity while creativity is mastery of simplicity."
DIHOWARD is offline
Old 08-25-2008, 05:16 PM   #7 (permalink)
pepsibluefloat's Avatar
Send a message via AIM to pepsibluefloat Send a message via MSN to pepsibluefloat Send a message via Yahoo to pepsibluefloat
sharpee.
__________________
1988 4runner::SAS|3vze|A340H|5.29's|Aussie Front|LockRight Rear|Longfield axles/Hub Gear|4"Rear/3"Front springs|Marlin High Steer|Custom CV rear driveshaft from High Angle Driveline|Rear D/S shortened and made into front D/S |35" Goodyear MT/R
My 4runner n stuff
pepsibluefloat is offline
Old 08-25-2008, 06:07 PM   #8 (permalink)
yotAddiction's Avatar
Send a message via AIM to yotAddiction
Coming from someone who works at a wheel/tire shop, balancing with lead pound on weights give much better results then the tape-weight. Tape-weights are great for passenger car tires. If you are try tape-weighting a light truck tire, you will end up using more weight then it is worth.
__________________
Run it 'till it wont!
yotAddiction is offline
Old 08-25-2008, 06:32 PM   #9 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
The shop that mounted my BFG's put the weights on the inside of the rim. Its nice not having to stare at ugly grey weights on the outside rim..
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 08-26-2008, 07:42 PM   #10 (permalink)
Midget96's Avatar
Tape weights then black duct tape over top. I saw a bunch of JGTC cars using this simple fix at the race in Fontana 4 years ago. Works fantastic.
Midget96 is offline
Old 08-26-2008, 07:54 PM   #11 (permalink)
yeah. just tell them to dynamic balance them.. static balance sucks...
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 08-27-2008, 05:56 AM   #12 (permalink)
dirtoyboy's Avatar
Quote:
Originally Posted by pyro View Post
blancing powder
I couldnt stop laughing for some reason when I read the thread title...
anyways....balancing powder sucks..if it gets wet it can clump and also can clog the valve stem if it decides to find its way out...
Try Dynabeads from Innovative Balancing if anything....thats what semi truckers use.
I use them on my 36" swampers...never required any additional weights or balancing and I can run em at 80 miles per hour..FWIW
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 08-27-2008, 07:33 AM   #13 (permalink)
mt_goat's Avatar
How much of that did it take to balance a 36" swamper?
BTW Collier, when you get a chance I'd like to buy that CV axle.
__________________
Dale
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 08-27-2008, 07:55 AM   #14 (permalink)
dirtoyboy's Avatar
check here..... http://www.innovativebalancing.com/BigTirechart.htm
sorry man i have been really backed up lately dale....I will get back to you very soon i promise
__________________
Old 08-27-2008, 08:06 AM   #15 (permalink)
mt_goat's Avatar
Thanks no rush, when you get time.
__________________
Dale
mt_goat is offline
Old 08-27-2008, 09:52 AM   #16 (permalink)
andtheman1988's Avatar
Send a message via AIM to andtheman1988
Be sure when you get them balanced wether your gettin them static balanced or dynamic ask the tire shop to use exact balancing. The best method of all is road force balancing. That way costs a little more because the tire has to me mounted a dismounted twice to line up the high and low spots of the tire and rim. I work at goodyear and have done that to my ltbs on steelies and i got my down to lesst that 2.5 onces total on each tire.
__________________
Myspace
94 p/u, 5 inch trail gear sas, Marlin Crawler Drop in 3rd with 5.29 gears and spool, shakles, 33x13.50s Super Swampers LTBs, 15' Steel Wheels, ARB Bull Bar Bumper, Warn M8000 winch, Warn Premium Hubs, 50 watt backup lights mounted on toolbox, Chip, K&N Air Filter, Animal House Horn, Cobra CB, Sun Pro Super Tach, Hurcliner,Turbo Muffler
NO LIMIT 4X4
andtheman1988 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Balancing steel wheels vs. aluminum regularguy412 Tires & Wheels 9 04-29-2006 07:50 PM
Should I get black wheels? grimpy 95.5-2004 Tacomas & 96-2002 4Runners 42 04-16-2006 05:49 PM
Black wheels... Tacoma750 General Vehicle Related Topics (Non Year Related) 33 02-08-2006 07:54 AM
green 2nd gen with black wheels vs. silver wheels Exeter 86-95 Trucks & 4Runners 8 02-08-2006 01:06 AM
Black wheels for snow wheels.. me like! UKMyers 95.5-2004 Tacomas & 96-2002 4Runners 21 12-13-2004 10:32 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
