| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
anyone do a writeup on cleaning the IAC (idle air control) valve?
__________________
07 4runner 4.7 SR5 98 4runner 3.4 SR5 87 FJ60 |
#2 (permalink) |
anyone?
__________________
#3 (permalink) |
I don't think I have ever seen a good writeup for that.
You will probably need to remove the TB because I think the IAC attaches with 4 screws on the underside. If anyone has a pic of that, post it up.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 04-07-2006 at 06:54 AM. |
#4 (permalink) |
hopefully in a couple of weeks i will be doing that on my 98 4runner, and a couple of camrys. ill defintiely try to document it. i just need to find out the correct method of cleaning it first.
does the whole throttle body need to come off?
__________________
#5 (permalink) | |
Quote:
*Edit* I just checked on mine and yes, you definately have to take off the throttle body to clean the entire IAC.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 04-11-2006 at 04:56 AM. |
#6 (permalink) |
im not sure if my IAC is dirty but last week the engine died on me while at a red light. dont know what the cause of that is. ill clean it regardless, im pushing 140k.
__________________
#7 (permalink) |
I had to take the whole TB off. I remember it being on the bottom of the TB. You may need to go buy a new gasket for the TB and for the seal between the IAC and the TB. Both of which are cheap.
I just tried cleaning it with Carb cleaner and a light brushing. I got the idea from here: http://www.iroczone.com/techartcleaniac.html I was having stalling issues at red lights too, normally after hard accel. I went on a long trip after cleaning it and it didn't stall. BUT, 2 months later it stalled once more. I may try cleaning it again now, because I don't think I did a very good job in the rain, 6 deg C weather. I've read somewhere that the TPS may be causing the stall too, so that may be my next step.
__________________
Richard '96 4Runner SR5 V6 5Spd TRD 2nd Gen S/C, TRD Hdrs, Borla Cat-Back, Walbro 190lph Fuel Pump, 305cc Injectors, SS FTC-1, Waydo (TRD) Lift Coils, Bilstein Shocks, BFG All-Terrains 285/75/R16 |
#8 (permalink) |
I might have to do this myself when I get some free time and post pics and a writeup for people to follow.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#9 (permalink) |
Did anyone ever do a writeup for the IAC cleaning? Do I need to replace the gasket and the seals? Do I use carb cleaner and what exactly do I clean?
__________________
1998 4Runner SR5 - 16" Remington Wide Brute AW Tires, K&N Airfilter, Deckplate Mod, ISR Mod, WAAG Donkey Killer Bars up front, WAAG Tail Light protectors in the rear, Kenwood MPV-622 Head Unit, Lightning Audio B400 Amp and 10" sub. |
#10 (permalink) | |
check coolant temp sensor. which engine model on camry? doesnt sound like a IAC to me.
Quote:
__________________
Tran, oO 4runner - Millenium Silver WTB: 01-02 4runner right(pass.) taillight .,~??▼.,~??▼.,~??▼ WTB: Hood wind deflector Last edited by profuse007; 09-20-2006 at 05:49 PM. |
#11 (permalink) |
I remember the FSM saying something about not getting carb cleaner on the IAC - reduces the life. FSM says to replace both gaskets - cost about $5.00 for both.
I have the parts - just need the time.
__________________
1996 Limited 4runner; Completely stock except for Yakima roof rack. |
#12 (permalink) |
If you have a scan for serviceing the IAC in the 1996 FSM I'd like to see that because I couldn't find anything in there saying anything about not using carb cleaner on the IAC (or ISC as it is sometimes called) for later year trucks. I'm not sure how you'd do that anyway because as soon as you use carb cleaner to clean the throttle body, I guarantee alot will go into the port for the IAC air bypass. I agree with the gasket replacement because by now most of the gaskets would be too brittle to reuse anyway.
__________________
#13 (permalink) | |
Quote:
In the 1996 4runner manual Pub# RM480U on page SF-24: CLEAN THROTTLE BODY (after it is removed) (a) Using a soft brush and carburetor cleaner, clean the cast parts. (b) Using compressed air, clean all the passages and aperatures. NOTICE: To prevent deterioration, do not clean the throttle position sensor and IAC valve. All I can do is tell you what the FSM says. I'm new at this and trying to figure it out as I go. This could be one of those things that everyone ignores without consequence. Anyway, the FSM doesn't say anything about cleaning the MAF but people clean it with electronic cleaner. So, I was thinking that I would use electronic cleaner to clean the IAC.
__________________
#14 (permalink) | |
Quote:
Thanks for putting that up so we have what Toyota recommends anyway. Cleaning the IAC with a can of CRC contact cleaner won't do hardly anything to remove the carbon buildup that causes the IAC to not function properly. Carb or top end cleaner will remove the carbon and should restore most of the performance. The IAC is nothing more than a cast housing, a DC stepper motor and a metering cone (often made of just metal or rubber/metal). None of those can really be hurt by the use of carb cleaner (if that were true you'd also see alot more people with issues who clean their throttle body regularly like I do). I haven't done it on my truck, but I have definately done this on countless other vehicles while working as a mechanic (often as part of my routine when doing a tuneup.....I used to get comments like "wow, I can believe how smooth the car is now" or "man, the car used to feel like it was going to stall at idle, now it just purrs"). Cleaning this device is not a "cure all" either though......it is just in some cases it has gotten to where the device just doesn't function at 100% and it will affect the idle speed. The manual is correct not to ever touch the TPS with anything, if it is malfunctioning, replace it outright. I think the FSM may be referring to the electrical portion of the IAC and that case I agree with that as well, you only need to clean the casting and the metering cone (don't mess with the motor at all). Unfortunately the FSM does read a bit vague.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 09-21-2006 at 11:42 AM. |
#15 (permalink) |
Anyone happen to have the part #'s for the gasket and the seal. Trying to explain to the guy at the parts counter at Toyota, will take forever.
__________________
#16 (permalink) |
Thanks for the info Jamie, it's good to know. You have de-mystified some of this for me.
The numbers on my invoice are: TB gasket: 22271-62040 IAC gasket: 22215-62180
__________________
#17 (permalink) |
Thanks Creek and MTL. I will try to get the parts tonight and I will let you guys know how it goes! Another stupid ? Does anyone know the torq specs? I am not sure if it is in the manual, I am at work, so I can't check.
__________________
#18 (permalink) |
13 ft-lbf for the four TB bolts/nuts.
__________________
#19 (permalink) |
Try this one!
I cleaned mine a while ago and posted something about it. I guess no one noticed. Hope this helps.
http://www.yotatech.com/showthread.php?t=92286
__________________
1999 4Runner SR5, V6, 2WD - LIFTED & LOCKED for backcountry adventures. 1997 Land Cruiser 40th Anniv. - Family Hauler. If it was my choice, "it would be lifted already!" "Don't laugh, they're both paid for!"
#20 (permalink) |
Thanks for the part #'s. I got the parts tonight. Not a mere $5 it was $17!!!
Sorry 99runner4me, I searched the Forum and did not locate this post. Thanks for posting the link again, it will deffinately help me out!!!! I'll let you know how it goes.
__________________
#21 (permalink) |
Took off the TB and cleaned it, and cleaned the IAC, it had a lot of carbon build up!!! I was real careful with using carb cleaner to clean it. Bolted it all back together and it fired right up. It seems to be running a lot better. It has a lot better throttle response and the idle seems to be a little higher and is not stuttering. I gave it WOT on the road and it did not die on me like before, but this problem has be intermittent.
I hope that that stalling problem is fixed. I will run it for a while and let you guys know the status. Mechanically it was simple to remove and re-install the TB, it was much harder to clean it. So to all you guys out there that have not done it, do it. If the 4Runner runs good for the next few weeks, I think that it is time for the Deckplate Mod!!!! Thanks a million for your guys' help!!!! If the problem is fixed, you all saved me a costly trip to the "stealership". To all of you that helped me on this project: If you are in my neck of the woods someday, let me know, and the beer is on me!!! Cheers! (_)3 Geoff.
__________________
#22 (permalink) | |
Quote:
Thanks for the report.
__________________
#23 (permalink) |
OK, I did it.
About 7,000 miles ago I cleaned the TB without taking it off. Now that I have cleaned the TB both ways, I won't clean it without removing it again. The hardest part is removing the hose clamps from the IAC. Is there a special hose clamp tool? If so, please tell me about it so I can buy one!! Since I had the TB/IAC off I decided to repalce the plugs too. After cleaning the TB and the IAC and replacing the plugs the 4runner is running very smooth. I replaced the PCV valve too. Bottom line - I think removing the TB is the better way to clean it. Plus, it allows you to clean the IAC too. I think I'll do this every 30,000 miles when I replace the plugs.
__________________
| Tags |
| 2221562180, techartcleaniac |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE Idle Speed Control Valve Test? | pcmentor | General Vehicle Related Topics (Non Year Related) | 4 | 05-28-2008 04:25 AM |
| idle air control actuator | kawibikelover | Newbie Tech Section | 0 | 07-14-2007 01:56 PM |
| 22re thermostatic idle air control | ripcurl | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-28-2004 12:21 AM |
| idle control valve | sskusc | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-26-2003 11:15 AM |
| "Idle Air Control" valve questions | AgRunner06 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-27-2003 10:49 PM |
