Any experts at shooting paint on a budget ? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-15-2006, 10:43 AM   #1 (permalink)
nrgetic99's Avatar
I am thinking about having a go at painting the chrome bumpers on my 98 Limited.
I have found some good tech articles on how to paint chrome but as I have a compressor (25 gallon, 6 cfm @ 90psi ) I was wondering if I have enough cfm to be able to do some limited painting ?
Anyone have a cost effective set up ?
Thanks
David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow
93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ...
03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-(
99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten
96 SR5 Dune... 1.5kw stereo
nrgetic99 is offline
Old 05-15-2006, 10:54 AM   #2 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
ive shot a few (small) things on my HF 2 gall pancake with my smaller touchup gun.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 05-15-2006, 11:14 AM   #3 (permalink)
nrgetic99's Avatar
Quote:
You sir, are a rockstar
David
__________________
Old 05-15-2006, 11:23 AM   #4 (permalink)
JuttyShabango's Avatar
You normally don't worry about the CFMs and should be using a Low Pressure, Hi Flow gun that feeds from the top.
Paint is easy to do, it's the prep work that gets most people. Use a quality primer and a decent paint.
Lay it in light layers allowing the paint to completely dry or "tack' before shooting another coat.
Use lots of fans to keep the overspray away from your paint.
Lots more to it, but that's the basics. Also, paint on the X Y Axis to get a consistent coat and seal it with clear
__________________
Mark Van Meter
Secretary, TLCA
#15080
www.tlca.org
The Buckeye Birfield Syndicate
www.buckeyebirfield.com
JuttyShabango is offline
Old 05-15-2006, 12:01 PM   #5 (permalink)
nrgetic99's Avatar
Great info.
Prep should not be too bad...I am very patient and a bit of a perfectionist.
Can you give me a couple more tips on the use of fans ? I am going to screen off the end of the garage with plastic sheet. SHould I use the fans to suck the air away from the piece or blow air over it toward the opening ?
I have a respirator.
Thanks a agin,
David
__________________
Old 05-15-2006, 12:07 PM   #6 (permalink)
Quote:
Originally Posted by nrgetic99
Great info.
Thanks a agin,
David
Use the fans to pull the air away from the object. You should be able to shoot some spray and see it travel to the front of the vehicle. Cleanliness is next to Gawdliness when its paint.
I have a couple furnace fans hooked up to a motor..but be careful with this set up as fire could result if motors are hot and alot of paint in the air. If this is the case...simply put a furnace filter infront.
One of my very good friends has a booth in his shop and does paint on the side.
__________________
Mark Van Meter
Secretary, TLCA
#15080
www.tlca.org
Old 05-15-2006, 12:14 PM   #7 (permalink)
nrgetic99's Avatar
Cool, I have a huge box fan and was going to rig a shroud. I will use an a/c or furnace filter.
David
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Going FAST on a budget... Bumpin' Yota Off Topic Talk 5 05-02-2007 06:31 PM
60mm TB on a budget... dcg9381 86-95 Trucks & 4Runners 8 11-27-2006 09:56 PM
Shooting Trip spindleshanks Off Road Trip Planning, Expeditions, Trips, & Events 85 06-11-2006 05:29 PM
Any other Canadians hear about the budget yet? stevrock Off Topic Talk 8 02-24-2005 07:45 AM
Budget dating Plays_with_Toys Off Topic Talk 33 12-18-2003 10:05 AM
2009 InternetBrands, Inc.
