Alignment Issues? Can't get your rig aligned after a lift? Info...
#41
This was a great thread--i was bashing my head thinking why cant the alignment guys get it right--well Today i took it to them and after putting on new tierod ends and replacing the upper A-arm bushings (lowers are a pain to get past the PS rack)--they still couldnt get it aligned--pulls crazy to the right and thy couldnt get the caster to get within spec. I am going to have to take it back.......
Crap--i am getting so fed up with people not knowing how to do something but saying they do.....BS
#42
this might give u an idea of general specs and that not only do u change angles by tightening them that tight but u r over tightening them however i do agree with u about alot of techs half assing jobs i think the problem is no one takes pride in their work ne more ne way a few specs just for some ref and alot of problems come when u change ride height and u run out of adjustment
Ft. Lbs. (N.m)
Land Cruiser
Front Adjuster Cam Nuts 72 (98)
Tie Rod Lock Nuts 41 (55)
Wheel Lug Nuts 76 (103)
Sienna
Lower Strut Mounting Bolts 155 (210)
Tie Rod Lock Nuts 55 (75)
RAV4
Rear Adjuster Cam Nuts 83 (113)
Lower Strut Mounting Bolts 117 (158)
Tie Rod Lock Nuts 41 (56)
Tacoma
2WD
Upper Control Arm Bolts 96 (130)
4WD
Front Suspension Adjuster Cams 96 (130)
Tundra
4Runner
Wheel Lug Nuts 81 (110)
Ft. Lbs. (N.m)
Land Cruiser
Sienna
RAV4
Tacoma
2WD
4WD
Tundra
4Runner
#43
for what its worth.. i lifted my IFS 4 inches and i had a problem getting the alignment straight... i had to cut my Tie rod engs like a half in or more off each end... could be a common prob..i didnt read the solution u posted first but .... yeah...
#45
Very informative post, its nice to be able to learn this stuff from one website. I have just started working on my 4runner myself recently, and every question i have had so far i have been able to find an answer/example from YotaTech.
#48
TRY acetone/tranny mix 50/50--soak it down good and go have a brew--watch Extreme 4x4 and use a quality ball joint seperator and not a pickle fork--
The rest is the reverse of removal
06-01-2021 01:51 PM
coffey50
07-28-2015 10:55 AM
skoti89
07-06-2015 07:45 PM
