Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
2nd & 3rd gen (runner) front diffs
im wanting to go to 4.56's. have the rear 8"'s...so now just need the fronts. dumb question, but will the front diff of a 2nd gen work on the 3rd gen? or are the r&p (and carrier?) the only things i can use? someone locally is selling the front diff, but i think its from a 2nd gen runner which is passenger side diff, hence my inquiry..
thanks
__________________
sonny ------- 1998 4Runner LTD. Fabtech CO fronts, OME/Pro Comp rears, SS rear links, Revtek diff drop, oem elocker, ARB RD90, 4.88's, 315/75/16 MT/R's on FZJ-80's, Trail Gear sliders, ARB Prado Bar, 1.5" 4Crawler BL, Tundra Brakes, wabfab disco's, IPF's...satoshi'd deckplated & ISR'd. SOLD!!! new ride: 1997 FZJ80. ome/arb/bfg/etc. when clinton lied..nobody died |
| Sponsored Links |
#2 (permalink) |
no. no interchaning at all.
you can only swap the rears if you change the whole thirdmemeber. you can't regear a 2nd ged thridmember with 3rd gen gears either. however, you are a direct rear swap for a tacoma TRD 4wd and a direct front swap from any 4WD tacoma with ADD and any 4WD tundra. they share the same front chunk (gears, housing, ADD, etc) with the 3rd gen 4runners. Last edited by bamachem : 09-21-2006 at 08:33 AM. |
#3 (permalink) |
aah crepp. so i cant even use the gears (not housing, carrier etc) from the 2nd gen diff? i thought all gens used the same 7.5" setup?
as for the rears, i was just gonna get the gears changed, not a whole 3rd swap since ive got the elocker...thanks for the info andy..i may just hold off till i can score some 4.88's then.
__________________
#4 (permalink) |
you can't use the front gears due to the different rotation since they have the pinion on the driver side with the diff pumpkin on the pass side and the 3rd gens have the pinion on the pass side of the pumpkin with the pumpkin itself on the driver side. essentially a mirror image causing reverse rotation in comparison of the gears. also, a different pinion placement causes the ring gear to be a different thickness.
sucks, but that's what i learned in researching my gear swap. the good news is that a 4WD TRD taco or or 4WD Tundra will work as a direct swap on the front - think of all the SAS/SAC threads on the tacomaterritory forum and the ones on the tundrasolutions forum... if you can find someone with a full diff for sale, then you just drop yours and bolt that one in it's place. Last edited by bamachem : 09-22-2006 at 09:45 AM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3rd Gen Front Bumper Ass. / Brush Gaurd & Tailight Guards & More | FJ40LVR | Misc Stuff (Vehicle Related) | 4 | 07-11-2007 10:26 AM |
| 2nd Gen 4runners & 3rd Gen P/U front Rotors | CoedNaked | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-30-2005 11:51 PM |
| 2nd Gen front diff in a 3rd? | kawaii005 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 02-12-2005 10:45 PM |
| 1st gen runner & 2nd gen truck chrome trim removal questions! | Ilovemountains | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-02-2004 02:52 AM |
| F.S.-1st gen 4-runner & questions about 2nd gen purchase | Dave | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-17-2003 08:51 AM |
