22re in a buggy - YotaTech Forums
Go Back   >
22re in a buggy
LinkBack Thread Tools Search this Thread
Old 05-24-2007, 07:44 PM   #1
22re in a buggy
I was wondering if anyone has personally put a 22re in a
dune buggy. My buddy's got a 85 2wd automatic truck that
is pretty much rusting of the frame, but the engine runs
good. I had an 84 celica GT with the same engine and it
was the funnest best running car I've had. (back to the
question) I've picked up a rail and want to put the 22re into
it. I have an adapter plate coming but what things can I
live without when installing it? Some one said I should change
it to carb. but we have the whole truck to take wiring off of. So
is fuel injection and the computer hard to transplant. Also will it
run without the o2 sensor that's on the manifold when I put on
a header. Any input would be appreciated.
Thanks
Coop
7485rail is offline   Reply With Quote
Old 05-24-2007, 08:15 PM   #2
notanymore's Avatar
i think if you could, it would be better to keep it efi. it will run without an 02 sensor but it will run like ☺☺☺☺, just extend the wire on the sensor to make it long enough to work. i dont know alot about sand rails but i wouldnt recommend having just open headers, i did that for a while on my truck and when i put the exhaust back on there was a noticeable increase in power
notanymore is offline   Reply With Quote
Old 05-24-2007, 10:53 PM   #3
rocket's Avatar
Running it off of propane could be an option.
rocket is offline   Reply With Quote
Old 05-25-2007, 01:34 AM   #4
KevinInSac's Avatar
Quote:
Is propane going to be able to supply the sustained high RPM's that a dune buggy would need?
KevinInSac is offline   Reply With Quote
Old 05-25-2007, 06:35 AM   #5
Robert m's Avatar
Quote:
better question would be.... would a 22re be able to supply the sustained high RPM's that a dune buggy would need?
Robert m is offline   Reply With Quote
Old 05-25-2007, 07:56 AM   #6
norcalsvx's Avatar
i've seen them in buggy's (efi's) and in VW baja bugs
norcalsvx is offline   Reply With Quote
Early TB air boot on late 22RE? ia02 86-95 Trucks & 4Runners 5 08-20-2015 12:04 PM
22RE LOUD Knocking Sound from Engine JNapolitano Newbie Tech Section 12 08-10-2015 08:18 AM
Troubleshooting my 1993 22re PlayAwhile 86-95 Trucks & 4Runners 5 07-20-2015 12:36 PM
Tags
22r, 22re, 2wd, 4runner, adapter, buggies, buggy, dune, exhaust, o2, plate, powered, propane, run, sensor, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
