Is this a 22R
Is this a 22R
Local guy has offered this to me....but he doesn't know anything about it...and frankly, I don't know quite enough to tell for sure. but it certainly looks alot like my 22RTE except with different intake and exhaust manifolds....
If you're looking for the shortblock, there are two different block heights. There's the "tall block" 84 and earlier and "short block" 85 and later. ~11" from bottom of block to top of block for the later ones, ~11.25" for the earlier ones.
If you want to put it into a pre-85, then you want the non-laser block, if you are putting it in an 85-up, then you want the laser block.
interesting...
didn't they switch to fuel-injection in '85? so, because this is carbed, it would have to be the 'non-laser' block? right?
what's the difference? I was going to use the shortblock to replace mine. drop my 22RTE head, intake, exhaust etc. on it. maybe swap pistons to lower my CR...maybe not. Would this not be possible?
Nope, has nothing to do with carbed or fuel injected. A 87 carbed engine has the same block as a 87 FI engine. A 84 fuel injected Celica has the same block as a 84 carbed.
You'll have to look into the swap... but without new pistons and possibly rods, I don't think it's possible.
I should mention, this did come out of a truck. not from a celica. wouldn't that make it a pretty safe bet that it's pre-'84?
I'll look into it...thanks for all the info!
If it came out of a 4Runner, it's a 84. If it came out of a pickup.... it could be up to a 87. By my unofficial estimation about 50% of the 85-87 pickups were carbed. At least the ones people are selling.
and yes, if I do get it (which I probably will, even if I can't use it, cause I don't think he wants anything for it), parts will be available....for pretty cheap.
buckz6319
08-05-2017 03:50 AM
Toys4parts
09-26-2015 01:56 PM
