| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
1986 Turbo 4WD SR5
#2 (permalink) |
There are lots of options, it all depends how much you want to spend.
You could go with a CT20, but they are expensive, hard to find and arn't that great. You could go with a CT26 off a Supra, or you could go with a T3 or T4. You've already seen Jeffs site, check out Darins: www.22returbo.net he's doing a mid dollar project. I'm doing a "low" dollar using mostly 22RE parts, and a T3(with an adapter on the manifold). I'm using a standard 22RE head, and Darin and Jeff are using pretty much regular 22RE heads(higher compression) with much much more head work than I've got.
__________________
86 Turbo Pickup EB Street RV head EB 268 Cam V6 Brakes + MC A340F auto ---> W56 5-spd swap ...I want a bigger turbo... |
#3 (permalink) |
Thanks for the link. Darin's site is good as well.
#4 (permalink) |
how much boost can this engine hold with the stock turbo and internals as well with a 100k mile engine?
__________________
1989 Toyota pickup 1997 Nissan 240sx redtop-sold 1987 Toyota turbo pickup 2004 Honda civc si www.hawaiiskindiver.com www.speedhawaii.com |
#5 (permalink) |
I wouldn't go more than 20-30 psi, but if you were to go that high, you'd obviously have to upgrade the intake and exhaust systems, as well as strengthen the front cover system by installing steel timing chain guides.
check Jeff's site at: http://www.well.com/user/mosk/ and Darin's site at: http://www.22returbo.net hope that helps |
#6 (permalink) |
with the stock turbo, though, about 7-12 psi. I'd ditch that for a CT26 or CT12A or Garrett, myself.
#7 (permalink) |
After doing a bit more digging I thing I'm going to swap my stock CT20 for a CT26 out of a supra.
I've got an adapter and a T3 sitting at home, I guess $$$ will dictate what I do. As for how much boost the engine can hold...yes I'm sure it could put up to 20-30lbs. The block is tough and with forged slugs rods and crank they'll take it. the head would need some beefing up as the stock one has some thin spots. However you'd have to consider deminishing returns. It's only a 2-valve engine, so you're going to have limited top end, so you can force as much air through the turbo as you want, but if it can't get in and out of the cylinders, what's the point? Also with a redline of ~5500RPM, a turbo putting out 30lbs, isn't going to be 30lbs at the TB...plus it'll probably only get to that level at what 5000K? how useful is that?
__________________
#8 (permalink) |
My 22R-GTE and 24R-GTE engines, on sale in starting sometime in 2009-2011, should take care of the SOHC 2 valve problem.
#9 (permalink) |
thanks for the input guys
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1986 4 runner 2.4 DIESEL TURBO | coupehq | 86-95 Trucks & 4Runners | 3 | 06-28-2007 06:56 AM |
| 1986 SR5 XTRA Cab turbo. What can I do to bring out some of the power? | Bociba | 86-95 Trucks & 4Runners | 13 | 11-24-2006 08:59 PM |
| 1986 SR5 turbo 22rte extended cab F.S. | audi.trevor | The Classifieds GraveYard | 2 | 08-16-2006 10:50 PM |
| 1986 Turbo 4x4 Questions | pagano | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 05-26-2005 09:09 AM |
| 1986 4x4 turbo! | 2doors | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 01-23-2004 03:53 PM |
