YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > General Vehicle Related Topics (Non Year Related)
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-25-2008, 03:41 PM   #1 (permalink)
1986 22R pickup...vacuum problems...stuck
Hello all,
Well my dad got this 86 pickup with the 22R, but I'm starting to believe it's got a different year motor (not sure...I'm a honda guy myself). Anyway...I've looked at the 85 and 86 diagrams and see that this truck has no ASV and an extra VSV with a little cylindrical plastic part on it, plus it's mounted sideways as opposed to the other one matching the diagram. I'm so lost as to how to correctly hook up the vacuum lines. The truck isn't idling right so I need to square this issue away first. Also, where does the vacuum line go from the "idle up diaphragm" (the one just below the automatic choke). Pictures of a correct setup would be ideal. Feel free to correct me if I made any mistakes in my description, as I'm still learning about these 22R's.
Thanks
crxsirg is offline
Sponsored Links
To remove this ad, register today!
Old 07-25-2008, 08:23 PM   #2 (permalink)
bump for some help
crxsirg is offline
Old 07-25-2008, 08:27 PM   #3 (permalink)
muddpigg's Avatar
http://www.ncttora.com/fsm/index.html
welcome, check the FSM
muddpigg is offline
Old 07-26-2008, 05:58 AM   #4 (permalink)
I already have the 85 manual and checked vacuum diagrams for 84-88 models. The problem is I don't know where the motor came from since it seems to be missing parts according to the diagrams. So I'm not sure if the missing parts are allowed to be missing or if I need to source them, and the vacuum diagrams don't show where all the lines connect on this carb...since apparently, this carb doesn't match the diagrams.
edit: Also, the vacuum diagram on the hood is completely worn off.
Here are the exact issues:
-no ASV...is this ok and what do I do with the lines that were supposed to connect to it?
-2 VSV's...what do I do with the second one (it has 2 plastic nipples and one metal nipple covered by a cylindrical plastic valve thingy)?
-where does the line from the Idle-up diaphragm connect (I can't see it in the manual)?
-no VTV...is this ok?
-Theres a metal vacuum line bolted to the carb that curves around the outer vent control valve...what connects to it because it's not shown in the manual?
I've searched here and used the manuals, but this is still puzzling.
crxsirg is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1981 pickup vacuum problems oleyoter Pre 84 Trucks 2 10-19-2007 12:04 AM
81 22r Vacuum Question trekker81 General Vehicle Related Topics (Non Year Related) 0 06-29-2007 02:31 PM
22r Vacuum Lines cal4runner Maintenance & Repair Archives 2 08-11-2005 10:14 PM
I need pics of 84 22r vacuum lines scubasteve83 95.5-2004 Tacomas & 96-2002 4Runners 4 09-02-2004 05:49 PM
22r carburetor vacuum diagram?? lostcreek21 95.5-2004 Tacomas & 96-2002 4Runners 2 11-28-2003 12:39 AM
hello
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
