1984 4x4 won't shift to 4wd ????
Is the truck new to you?
If not, have you ever been able to shift the transfer case in the past??
Removal of the shifter and examination of the shifting rails and shifter bottom button might be enlightning.
Yes its new to me but IT has been in the family with one owner and he said when he parked it that it worked but I have never shifted it someone said there is a spring that might not be working right but I don't know where this spring is even located ????
Here is a link to the 1985 FSM.
Your truck should be similar. --
http://www.precision4wheeldrive.com/1985FSM.pdf
Takes a while to load.
Might look here as well--
http://web.archive.org/web/201209012...fsm/index.html
The FSM is great,
The FSM is great, but I don't think it recognizes aftermarket issues like
a 3 inch BL which is affecting my TC shifting, other resources cover the slack though...
J
J
Does this Pickup have the AISIN 4x4 Locking Hub Dial? Or is it not shifting in the transfer case? The Locking Hub Dial has a spring that goes in and out depending on freewheel of locked wheels to the axel.. check the front tires
Seattle_Sign_Guy
07-12-2015 12:38 PM
crashburnoveride
07-10-2015 06:39 AM
