why does my new clutch chatter at me? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 11-16-2009, 09:51 AM   #1
Hardstripe's Avatar
My clutch chatters when idling or in gear.. only time it doesnt chatter is when i depress the clutch. It stops chattering when the clutch is depressed about an inch. The clutch begins engaging at just under half way up. This is a brand new clutch on a 95 4runner with the 3.0 v6. It is a centerforce dual friction clutch. When I run my truck it smells like burning clutch. Ive got about 2500 miles on the new clutch since it was installed.
Thanks in advance, I appriciate it.
Hardstripe is offline   Reply With Quote
Old 11-16-2009, 09:54 AM   #2
91Toyota's Avatar
Did you have the flywheel resurfaced?
91Toyota is offline   Reply With Quote
Old 11-16-2009, 03:03 PM   #3
eddieleephd's Avatar
Quote:
X2 and as well did you get a new pressure plate?? and did you bleed your slave Cyl till it was clear to make sure there is no air in the lines and all is fresh??
eddieleephd is offline   Reply With Quote
Old 11-16-2009, 04:16 PM   #4
User Requested Ban
because he never read this forum?
chances are it was installed backwards ... i've seen that happen.
theAuthority is offline   Reply With Quote
Old 11-16-2009, 06:49 PM   #5
Hardstripe's Avatar
i didnt install it, the college students did it for free... lucky me.
Old 11-16-2009, 09:59 PM   #6
What you got against Centerforce??? I will repeat my question did you do a new pressure plate???
Old 11-16-2009, 10:25 PM   #7
Hardstripe's Avatar
yea i had them replace everything new. Im thinkin they put the wrong size throwout bearing in, i called centerforce and he told me thats what it sounds like, apparently the clutch i have takes a smaller version... ultimately i think ill end up having to pull it apart to see what it looks like. should be interesting 8) and will be a first for me. Ill post some pics when i get to it... heres what happened last time i did something for the first time on my new truck...
http://www.yotatech.com/f88/project-save-yota-183948/
Old 04-29-2010, 08:31 AM   #8
Disk in backwards or you have hot spots (hardened areas of the flywheel or pressure plate). This can be seen after the clutch is broken down and inspected. I am putting a Centerfource 2 clutch in my jeep as I already have one in my 87 4Runner and I am very happy with it. My jeep is currently torn down in the carport being restored. I am getting ready today to set the engine and transmission in on a powder coated frame and new suspension.
divedude is offline   Reply With Quote
Old 04-30-2010, 05:08 AM   #9
totally a bro
Staff
vital22re's Avatar
improper installation of pressure plate/clutch disk is my guess. Maybe presure plate wasn't torqued down right.
vital22re is offline   Reply With Quote
Old 04-30-2010, 05:39 AM   #10
iselloil's Avatar
Its in backwards
iselloil is offline   Reply With Quote
Old 04-30-2010, 05:40 AM   #11
xxxtreme22r's Avatar
if the college did it, I would take it back to them to do.
xxxtreme22r is offline   Reply With Quote
FS[MidAtl]: 1979-1983 Pickup Parts For Sale - Post Build Garage Clean Out kawazx636 Vehicles - Parting Out 31 02-23-2016 12:57 PM
Noob help. Is the 3vze that bad? To keep or sell '90 pickup 3vze 4x4, 160k, manual primordialbeast117 86-95 Trucks & 4Runners 11 12-19-2015 01:23 PM
smilen724's 1993 4runner Build Thread smilen724 86-95 Trucks & 4Runners (Build-Up Section) 13 11-08-2015 05:11 PM
g52 transmission question regarding axial movement?? hiluxinargentina 86-95 Trucks & 4Runners 0 10-01-2015 12:12 AM
please help me! Problem opening trans case G52 hiluxinargentina 86-95 Trucks & 4Runners 3 09-30-2015 06:51 PM
Tags
03, 1999, 4runner, brand, centerforce, chatter, chattering, chatters, clutch, cobra, dual, engaging, forum, friction, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
