| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
When it comes to Bolt-on or Welded, whats better and why?
__________________
* 3 inch Body Lift * * Homemade Snorkel * * 34" 10.50 Super Swampers * * FlowMaster Exhaust * * 4 point harnesses * |
#2 (permalink) |
Bolt on assuming you bolt through factory drilled holes. Drilling holes in your frame weakens your vehicle. I would weld on before i drilled my frame, but once you weld something, your gunna have a hell of a time getting it off.
__________________
1996 Tacoma SX... MT's! 1998 Jeep Wrangler Sport 4.0, 2.5 inch OME, Warn Bumpers, Shrockworks sliders 2003 Foes ZZ, Marzocchi 888, Chris King Hubs and Head. Ready for Whistler! |
#3 (permalink) |
I'm partial to bolt-on too and that's how I'm goiing to do my sliders so I can remove them with ease if I choose.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#4 (permalink) |
weld the bumper on it will give it more strength
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1972 stepside jimmy d44/d70 425hp 1995 green range rover |
#5 (permalink) |
I welded my sliders directly to frame....no regrets. Way stronger than bolts. As for a bumper however, I think I would want to bolt it on. Especially a front bumper as no-matter how strong it is built I guarantee you will bend, or dent it at some point and need to take it off to fix/fab it back together...that is unless it's on a "truggy".
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. 1983 SA Axle Frameoff Restore. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5 -=NO BAMA 08 =- |
#6 (permalink) |
Weld it and call it done. My first armor mods started out as bolt-ons using nutserts...my mentors suggested welds...I went against their advice. I guess I was thinking I was wanting to keep it modular for repainting etc.
Halfway through the build...just welded stuff and didn't look back. If you need to do surgery later on just put the Sawzall and grinder to use.
__________________
88 4Runner SAS/LCE 4" Lift 35" BFG 4.88/4.7 Twin Stick Aussie/Lockrite |
#7 (permalink) |
weld if your useing a winch ... I keep snaping bolts and then said the hell with it and welded it to the fame havnt had a problem since... course its a 3/8 steel bumper things are just gonna bounce off.
#8 (permalink) |
I bolted my front bumper on:
http://www.4crawler.com/4x4/4R_bumpers.shtml#Front It is plenty strong and I prefer bolting for things like bumpers and sliders. Why? For one thing, they are subject to potential damage and if damaged, they can be more easily replaced. Also, I have had my front bumper on and off probably a dozen times over the last 10 years. And the mounts have been modified 2-3 times over that time to raise the bumper, for adding things like tow hooks and tow bar mounting points, and for access to parts like the steering box/hydro assist fittings, etc. And I have done a fair bit of winching, first time out I stalled the 9000# Warn and another time winched a full size Suburban off the side of a road and caught it as it started to slide over into the ditch. Winch and front bumper did not budge. The key is setting up the bolts properly. For example, I have 4 - 1/2" bolts in shear on the bottom of the bumper and then 2 massive 3/4" bolts through the body mount brackets in tension to hold the winch pull. A few other smaller bolts into existing frame holes add a little strength, but having many different bolts in different planes really helps. Sure, if you just put in the 4 stock bumper mount bolts (all in the same plane), that is probably not enough to hold a winch bumper. But if you have the absolute final setup on your truck and want something fast, welding does work OK, too.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 02-16-2008 at 08:33 AM. |
#9 (permalink) |
Depends on how good you can weld! You do not want it ripping off because welds were not up to snuff. Very bad for your friend pulling you! Bumper through his windshield makes for a very bad day!!! (Seen it happen)If you go weld on, put a few bolts as backup, 1/2"-grade 8 or better, that should do it. I bolt everything to ensure that I do not rely only on my welding skill alone. A few bolts through the frame will not weaken things very much, and gives good piece of mind.
__________________
Toyota does it Better, Longer, Faster, Stronger. |
#10 (permalink) |
both have their benifits. welded is stronger but is harder to fix if you need to take it off because you have to cut it off. bolt on goes on and comes off way easy but it isn't as strong.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| quick question, whats the bolt for on the oil pump? | skife | 86-95 Trucks & 4Runners | 6 | 12-05-2007 05:35 PM |
| Lockers VS Welded | CRONK4X | Pre 84 Trucks | 13 | 11-19-2007 01:55 PM |
| bolt on v.s. welded rock sliders | weakyota91 | 86-95 Trucks & 4Runners | 4 | 06-13-2007 08:15 AM |
| do you need something welded ? | Ric | The Fab Shop | 10 | 08-03-2005 04:58 AM |
| broke a bolt Whats up with torque wrenches. | Duec66 | Maintenance & Repair Archives | 18 | 04-21-2005 04:21 PM |
